Client side validation not working on 2nd form in a page
Thread began 3/04/2010 10:28 am by david.barrack304604 | Last modified 3/04/2010 5:49 pm by Eric Mittman | 893 views | 1 replies |
david.barrack304604
I have a page with many forms. Client side validation is working just fine in the first form. In the form below it, each time I run through the WA Client Side wizard the validation info I enter is not saved. For whatever reason after I run the wizard WA picks up a hidden field, applies some validation, and ignores whatever was entered in the wizard.
For form where this is happening is form5. The validation that keeps stubbornly reappearing is "WAValidateRQ(document.forms[0].hf_room_count,'- First Name is required',false,0,false,'hidden');WAAlertErrors('The following errors were found','Correct invalid entries to continue',true,false,false);return document.MM_returnValue".
I am NOT seeing the Insert Record server behavior listed in the Server Behavior panel and think that may have something to do with it but really have no idea.
The code for the page is attached.
Thank you,
David
PRV_make_reservation.php.zip
It seems that the code for the inserts may have been altered slightly, if this is the case it could be the cause for them not showing up in the list.
When it comes to applying the client validations on the problem form you should try manually applying them and not with the wizard to see if you get a different result. You would start by selecting the form and in the Tag panel you would add a new client validation and just build them up one at a time from there. This should eliminate the issues you are experiencing when applying the client validations through the wizard.
