setting database up once site is finished
Thread begun 2/24/2010 3:16 pm by ant.knott394719 | Last modified 2/25/2010 9:50 am by ant.knott394719 | 3998 views | 3 replies |
ant.knott394719
Wasn't sure where to post this thread. My site is more or less complete and i would like to make it live. I've transferred the files to the host server but i wasn't sure about how to get the database to them. After trasfering all the files I put in the url and tried to access the site online but i got a database error message onscreen.
I realised i had to set up a user using the wizard provided on the cPanel of the hosting company so i set up a database user with the wizard and then i used there phpmyadmin to try to import the sql file that i had done a backup for. I'm not sure if this was the right thing to do, probably not as i got an error message 1044 which is similar to the one you get if you try to access the site online.
Warning: mysql_pconnect() [function.mysql-pconnect]: Access denied for user 'latineyes_user'@'localhost' (using password: YES) in /home/latineye/public_html/Connections/latinsite.php on line 9
Fatal error: Access denied for user 'latineyes_user'@'localhost' (using password: YES) in /home/latineye/public_html/Connections/latinsite.php on line 9
When setting up the database user on the hosts admin area (cPanel) am i supposed to be putting the information in exactly as it is above or are you meant to come up with a new username and password. I'm assuming its a new name and password as they only give you a maximum of 7 letters.
Any ideas where i'm going wrong?? I asked the hosting company about the above and they told me to check the hostname is localhost 'well, it is on the php page' and that my username and password is correct but i don't know where i am supposed to be checking this information and comparing it against.
One other thing, how do you know if the hosting company has the database, does it get transferred when you transfer all your web pages and files or is it something that need to be done separately such as importing it with phpmyadmin like i tried earlier??. i'm very confused, i thought sending the files would be the easy bit.
ant.knott394719
database problem - trying to get my site online
The hosing company advised me to export the file using phpmyadmin and then import from
phpmyadmin in the cPanel even though the WA video tutorial i watched demonstrates how to transfer the database by selecting backup. Perhaps you can do either of these and it's ok, i don't know? Any way i exported the file and saved it in my documents folder and then i attempted to import from the cPanel but i got the following message.
CREATE TABLE `agecategory` (
`ItemAgeID` INT( 10 ) NOT NULL AUTO_INCREMENT COMMENT 'Unique ID for age range',
`ItemAgeName` VARCHAR( 50 ) DEFAULT NULL COMMENT 'Age range',
PRIMARY KEY ( `ItemAgeID` ) ,
KEY `AgeID` ( `ItemAgeID` )
) ENGINE = INNODB DEFAULT CHARSET = latin1 ROW_FORMAT = COMPACT AUTO_INCREMENT =5;
MySQL said:
#1046 - No database selected
Any ideas what this means or what i'm doing wrong. If you could just point me in the right direction that would be great.
ant.knott394719
ok i've managed to to do a successful import using the host company's phpmyadmin
in the cPanel, when i exported my sql file and saved it on my computer i think i had forgotten to check all the tables, i exported again only this time i chose check all boxes. Once all the tables were ticked i pressed go. Then did an import in cPanel and it worked, no error messages, i was very pleased until i tried to access the live site and realised there was still a problem. Its the same one as before
i have no idea what i do now, i'll try asking the hosting company again but if you have any ideas please let me know. i'm obviously not doing something right.
ant.knott394719
All sorted, after uploading the database the hosting company were able to fix the problem.
