Passing Session Variables - Help?
Thread begun 4/27/2009 4:23 am by phil.evans372967 | Last modified 4/28/2009 5:10 am by phil.evans372967 | 7814 views | 7 replies |
phil.evans372967
Hi all,
I'm having trouble trying to pass a variable from one page/form to another and hope you can help.
I have two tables - prop_details and prop_images - I created a relationship using prop_id in both tables.
My first insert form posts data to prop_details and then redirects to my second page/form where I want to display two session variables (prop_id and prop_ref from prop_details) and then pass those to prop_images to create the relationship.
I have created a recordset in my 2nd page/form but cannot display the two session variable to post to prop_images
SELECT prop_id, prop_ref
FROM prop_details
WHERE prop_id = colname
what am I doing wrong?
With thanks
Phil
phil.evans372967
Update
Thought I'd post my code as it may be helpful. Pulling may hair out trying to get this to work
<?php require_once("Connections/prop.php"); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once('Connections/prop.php'); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$colname_GetIDsForIms = "-1";
if (isset($_SESSION['prop_id'])) {
$colname_GetIDsForIms = (get_magic_quotes_gpc()) ? $_SESSION['prop_id'] : addslashes($_SESSION['prop_id']);
mysql_select_db($database_prop, $prop);
$query_GetIDsForIms = sprintf("SELECT prop_id, prop_ref FROM prop_details WHERE prop_id = %s ORDER BY prop_id ASC", GetSQLValueString($colname_GetIDsForIms, "int"));
$GetIDsForIms = mysql_query($query_GetIDsForIms, $prop) or die(mysql_error());
$row_GetIDsForIms = mysql_fetch_assoc($GetIDsForIms);
$totalRows_GetIDsForIms = mysql_num_rows($GetIDsForIms);?>
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $prop;
$WA_table = "prop_images";
$WA_sessionName = "WADA_Insert_prop_images";
$WA_redirectURL = "prop_images_Insert.php";
$WA_keepQueryString = true;
$WA_indexField = "img_id";
$WA_fieldNamesStr = "img_id|img_thumb|img_main|prop_id|prop_ref";
$WA_fieldValuesStr = "".((isset($_POST["img_id"]))?$_POST["img_id"]:"") ."" . "|" . "".((isset($_POST["img_thumb"]))?$_POST["img_thumb"]:"") ."" . "|" . "".((isset($_POST["img_main"]))?$_POST["img_main"]:"") ."" . "|" . "".$row_GetIDsForIms['prop_id'] ."" . "|" . "".$row_GetIDsForIms['prop_ref'] ."";
$WA_columnTypesStr = "none,none,NULL|',none,''|',none,''|none,none,NULL|',none,''";
$WA_connectionDB = $database_prop;
if ($WA_redirectURL != "") {
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>Insert prop_images</title>
<link href="WA_DataAssist/styles/Refined_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="WADAInsertContainer">
<form action="prop_images_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHeader">Insert Record</div>
<div class="WADAHorizLine"><img src="WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">img_id:</th>
<td class="WADADataTableCell"><input type="hidden" name="img_id" id="img_id" value="" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">img_thumb:</th>
<td class="WADADataTableCell"><input type="text" name="img_thumb" id="img_thumb" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">img_main:</th>
<td class="WADADataTableCell"><input type="text" name="img_main" id="img_main" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">prop_id:</th>
<td class="WADADataTableCell"><?php echo $row_GetIDsForIms['prop_id']; ?></td>
</tr>
<tr>
<th class="WADADataTableHeader">prop_ref:</th>
<td class="WADADataTableCell"><?php echo $row_GetIDsForIms['prop_ref']; ?></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="WA_DataAssist/images/Pacifica/Refined_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="prop_images_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="WA_DataAssist/images/Pacifica/Refined_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
</div>
</body>
</html>
mysql_free_result($GetIDsForIms);
Add code to the top of your page:
phil.evans372967
Still no joy
Hi Ray
Thanks for your help.
I have added that the the top of my second page and still can't get the 2 session variables to display. I've spent 3 days on this now and I'm sure I'm doing something simple wrong, but can't see the wood for the trees.
My code now looks like this
<?php require_once("../Connections/prop.php"); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once('../Connections/prop.php'); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$colname_Recordset1 = "-1";
$colname_Recordset1 = (get_magic_quotes_gpc()) ? $_SESSION['prop_id'] : addslashes($_SESSION['prop_id']);
$query_Recordset1 = sprintf("SELECT prop_id, prop_ref FROM prop_details WHERE prop_id = %s", GetSQLValueString($colname_Recordset1, "int"));
$Recordset1 = mysql_query($query_Recordset1, $prop) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);?>
$WA_redirectURL = "prop_images_Results.php";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "img_thumb|img_main|prop_id|prop_ref";
$WA_fieldValuesStr = "".((isset($_POST["img_thumb"]))?$_POST["img_thumb"]:"") ."" . "|" . "".((isset($_POST["img_main"]))?$_POST["img_main"]:"") ."" . "|" . "".$row_Recordset1['prop_id'] ."" . "|" . "".$row_Recordset1['prop_ref'] ."";
$WA_columnTypesStr = "',none,''|',none,''|none,none,NULL|',none,''";
<head>
<link href="../WA_DataAssist/styles/Refined_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="../WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="WADAHorizLine"><img src="../WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<tr>
<td class="WADADataTableCell"></td>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
<td class="WADADataTableCell"><?php echo $row_Recordset1['prop_id']; ?></td>
</tr>
<tr>
<td class="WADADataTableCell"><?php echo $row_Recordset1['prop_ref']; ?></td>
</tr>
</table>
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="../WA_DataAssist/images/Pacifica/Refined_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="prop_images_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="../WA_DataAssist/images/Pacifica/Refined_cancel.gif" /></a></td>
</tr>
</table>
</div>
</form>
</div>
</body>
</html>
mysql_free_result($Recordset1);
The problem must be where they are set, since they are referenced correctly here.
phil.evans372967
have i set them wrong?
Here's my first page. Does dataassist set them automatically or do I need to manually set them somehow?
phil.evans372967
Sorry Ray, thought I'd attached my code. Will try again ...
phil.evans372967
Update
Hi Ray
I figured it out and added
$_SESSION['WADA_Insert_prop_details'] into my recordset for my second form, WADA_Insert_prop_details being the session variable from my first form and that seems to work fine.
Regards
Phil
