Help with form validation
Thread begun 4/22/2009 11:18 am by Brainthief | Last modified 4/24/2009 6:33 pm by Ray Borduin | 8503 views | 15 replies |
Brainthief
I think my problems posted in the two threads below are the same:
showthread.php?t=613
showthread.php?t=644
I think my form is not posting to the correct page.
I added server side form validation to checkout.php with the form action posting back to checkout.php to preform the validation...
Validation is working fine. My rules are working as they should.
The problem is in moving on the the confirm page...
Where on the validation page (checkout.php), after validation, does the page get sent on to confirm.php?
Change the form action back to go to the confirm page and copy and paste your validation code from the top of the checkout page to the top of the confirm page and you should be good to go.
Brainthief
I see...
I think that's what I needed!
Thanks Ray...
Brainthief
That looks like what I needed to know, but...
I'm using a template system and I'm calling my pages like this:
index.php?page=checkout
If a user inputs something wrong on the index.php?page=checkout form,
it goes to index.php?page=confirm where it fails validation.
It should send the user back to index.php?page=checkout to correct the fields, but it sends the user back to index.php?page=Checkout&page=Confirm
This sends the user on to the confirm page which is wrong.
How do I keep it from adding &page=confirm to the query string?
Thanks!
On the page WAVT_Scripts_PHP.php it has code that automatically adds querystring variables to the end of the url. It is on lines 64-70. You could probably comment out that code, or better yet create a copy of the function and add it to your page so that you can comment out a local version and don't need to update the central include.
It is sometimes necessary to maintain the url parameters on update pages, so it is done automatically. I hesitate to have you remove it from the global function in case you ever use validation on an update page. Also reapplying the server behavior would overwrite the file.
Brainthief
I see!
That's what I needed to know
Again Ray, Thank you.
I appreciate you working with me on this.
I think I'm moving forward now!
Brainthief
Alright, maybe another easy one.
I'm not getting a "stop" at confirm.php page...
Everything seems to be working with UPS and Paypal but after validation, it rolls right on to checkout_success.php.
I see the order in the database.
Shouldn't the process stop at confirm.php so the user can click the "Submit Order" button, then continue on to checkout_success.php?
Thanks!
Yes it should. Perhaps you are using the "any form submit" trigger to insert the order and process the transaction, so the submit from the checkout page immediately triggers the insert without confirmation. That is one possible cause of what you describe.
Brainthief
Yes, you are correct - I have any form post selected.
I got tis from the docs;
"Any Form Post: Any form posted to the page that the server behavior is applied to will trigger validation. This is typically used when a form on a different page is submitted to the page for validation."
I tired all of the other choices in the drop drop down and got the same results.
I checked the dynamic options but was not sure where to start...
Can you tell me which option I should choose?
Thanks!
Use the button press trigger event that triggers based on the name of the button used to submit the form and make sure the button names on your checkout and confirm page are not the same. That way you can differentiate when each server behavior triggers.
