CSS Sculptor error!
Error:
While executing onLoad in wacs_wizard.htm, the following JavaScript error(s) occurred:
In file"wacs_wizard":
InitializeUI is not defined
Error:
I had exactly the same issue this morning - Only change made recently was upgrade of data assist
I cleared the winfilecache
your user folder \AppData\Roaming\Adobe\Dreamweaver CS4\en_US\Configuration
And all now seems to work - Hope that helps
Yes, deleting the Dreamweaver cache file from the users configuration folder should resolve the issue:
Yes Jason, deleting the maccache file worked perfectly. Thx.
