Checkout does not work.
Thread begun 8/25/2009 1:27 pm by larsentim278054 | Last modified 8/28/2009 12:08 pm by Eric Mittman | 4767 views | 5 replies |
larsentim278054
I am using Authorize.net payment gateway. I've added my credentials in the global file. I can't get checkout.php to work. It loads the form fine, but no matter what, it will not accept any of my VALID credit cards. In my global file, I have tried putting the testing to True, and false, and in authorize.net section of the global file, I have tried putting the testing sandbox to true and false, and none of those options produce any good results when entering my actual credit card information. always says that it can't do the transaction, try checkout again. (like I put a bad information in). In my authorize.net setup (on their site), I have it in testing mode because I didn't want any charges to actually go through.
I've setup eCart checkout pages before with other custom sites, just not with this powerstore setup. So I do know how to get it to work with other "regular" sites that I'm taking payments for.
I haven't changed anything in the cart behavior or the checkout process other than adding the necessary information into the global file.
What do I need to do to get this to work??
If your Authorize.NET account is set to be in test mode then you may need to use a test credit card to get the transaction to go through properly. If this is the case you should have this information available to your somewhere on the Authorize.NET site when you login.
If you have it set to be test mode from your account you should make sure that you do not have test mode enabled in the globals file in any way, they should be set to false here.
It sounds like you are just getting the regular text message on the failure page, to get a more meaningful response on this page you can use the response reason text binding to show the reason. If it is not clear then you can add in the full request and response bindings onto the page to get at all the details.
Here is the code for the response reason text, put this on your checkout failure page where you would like to see the message:
<?php echo(AuthNet_Result("Response Reason Text")) ?>
These next two bindings are for the full request and full response, you would also place these on the checkout failure page where you would like to see the messages:
<?php echo(AuthNet_Result("Full Request")) ?>
echo(AuthNet_Result("Full Response")) ?>
larsentim278054
Hi Eric,
Sorry- I should've noted this thread today - because I got this figured out now. What was happening was the shipping part of the process was erroring out because I was using UPS and using the HTML Access Code instead of the XML access code (I guess they are handled differently) and wasn't allowing the order to go through. Once I fixed that, everything seems fine now.
Thanks!
That is good to hear, thanks for letting us know.
larsentim278054
Did you see my other question in this thread: showthread.php?t=3596
Could you provide some help?
Thanks!
It looks like Jason has just responded to that one. If you need any further help it would be best to post back to the original thread.
