Runtime Error
Thread begun 8/09/2009 10:07 am by Paul | Last modified 2/18/2010 8:14 am by Andrew Read | 15553 views | 19 replies |
PaulBeta Tester
Runtime Error
I'm using Data Assist.
When I run the wizard it takes me through 10 steps without problem.
During the 10th step, and i guess as it attmepts to write the necassary files before closing, I get an error which i've screen grabbed and uploaded as attached image.
The app and CS4 lock and i have to close using task manager.
I'm using v205.
Grateful for a solution as i'm not able to complete this task with its current behaviour
Paul
This error usually occurs if you set the "Create Links Relative To" option to "Site".
Go to Site Manage Sites, Select your site then click edit. On the Local Info Tab, change the "Create Links Relative To" option from "Site" to "Document", then try running DataAssist again. you can change it back to Site after the pages are created.
PaulBeta Tester
Hi, the value was setup as relative to document.
I've removed then reinstalled the extension.
Even tried another sql table
It's puzzling because it was working fine a few days agon on a different table, from which it created a full compliment of pages.
Unfortunately, this error now seems to be a permanant fixture.
We will need to look into this issue with you to find the cause. I have created a technical support ticket for you. Please update the ticket by logging into your support history at:
simmo515303621
Same Error for me
Hello,
Yes I have exactly the same error:
Runtime Error!
Program C...
R6025
-pure virtual function call
My links were and still are set to Document - i have also tried remove and re-install of the extension ( 2.0.5 & CS4 ) and also on a new table and DB... The extension has been working great up until now.... I have a proect due in the next few days - this has been a big set back - the quicker the support response the better.
Hervé
Runtime Error! Program C... R6025
I'm the third people having exactly the same error:
Runtime Error!
Program C...
R6025
My links are set to Document - i have also removed dw cs4 cache but whitout any change.
i'm using dw cs4 webassist 2.06 on a new xp sp3 computer. i was previously using interakt products and i try to set up a wa development environment. I'm surprised to be the third people to cope with the same problem without finding any technote regarding this issue.
thanks for your help
Hervé
The first report that I opened up a support ticket for did not respond when asked for a phone number so we could trouble shoot the problem.
The second person to report the problem came back to say that "I restarted my PC and on restart removed the WinCache file" fixed the problem for them.
try rebooting the computer and deleting the Dreamweaver cache file once again, If that does not resolve the error, I will start a support ticket for you as well.
tony181742
Same R6025 error
Bought this extension as part of the library and it has never worked. Have got links set to document have deleted my wincache file multiple times and rebooted a dozen times with no joy.
It runs through the 10 steps and when it tries to produce the pages get the error and DW crashes.
very disappointing
Hervé
R6025 error
i must mention i still have same problem using dreamwaever cs4 but only using data assist wizard, other extensions seem to work fine (i didn't test all of them)
fortunatelly data assist wizard is working fine using dmx8 on the same desktop pc, this is my present bypass.
pc dual core 4gb 2x500gb raid1 xp sp3 (french) - remote server PHP Version 4.4.6 (php info phpinfo.galacsys.com/ ) mysql 5.0.51a
