PowerBuilder
Thread begun 11/22/2011 3:16 pm by rob294118 | Last modified 11/28/2011 12:08 pm by Jason Byrnes | 4405 views | 10 replies |
rob294118
PowerBuilder
I am trying to Add CMS Content to a page on my website. I am getting an error message (see attahced).
I set up my connect and tested it in PowerBuilded and it connected successfully.
Dani Chankhour
The error usually happens when the testing Server is not set up correctly or that is the Connection file is not uploaded to your testing server.
You might want to also delete and recreate the site in DW and see if that helps.
If you are still getting an issue, i have attached a file that should let you pass the error message. however, i recommend that you still check your testing server setting to make sure you are uploading the files in the correct location.
rob294118
Where do I copy the file?
Dani Chankhour
Sorry, that file needs to go in the Commands folder under the Dreamweaver Configuration folder.
To find your Dreamweaver Configuration folder, read the following PDF:
rob294118
I did what the instructions said and get no new messages when I try to add CMS Content. It still can't connect.
Dani Chankhour
The message will still show up but it should still go through and finish the process.
Try deleting the cache file in the DW configuration folder and try it again.
rob294118
I already did all that.
Dani Chankhour
Can you please explain what exactly is happening? What happens after you click the Ok button when you get the alert.
rob294118
I got the install to work but am getting and error before it finishes. What does this mean?
Warning: require_once(../images/installed.png) [function.require-once]: failed to open stream: No such file or directory in /homepages/20/d184490718/htdocs/DoubleExposurePhotoBooth/WA_Globals/WA_Globals.php on line 60
Fatal error: require_once() [function.require]: Failed opening required '../images/installed.png' (include_path='.:/usr/lib/php5') in /homepages/20/d184490718/htdocs/DoubleExposurePhotoBooth/WA_Globals/WA_Globals.php on line 60
rob294118
I got it installed but the menu bar is messed up and the "Add Content" button does nothing.
Please open a ticket for me.
