Detailed steps to insert content ?
Thread begun 7/12/2009 12:27 pm by brunodarwin371999 | Last modified 7/13/2009 9:47 am by Neil Beadle | 1757 views | 1 replies |
brunodarwin371999
My PowerCMS is properly installed. I can see everything is correct on internet.
I have created one page for test. I have named this page »indextest.php »
In this page, I have defined two editable regions : « EditRegion1 » and « EditRegion2 ».
In this page, there are of course also several div blocks such as « body », « header », « footer », « content » etc.
PROBLEM : in When I try to insert my first and new content, I enter the name of the page «indextest » and the area content » footer » e.g. ,
But finally,I always have a message error when I click « ok » :
• Entry is required (Content Page)
• Entry is required (content ID)
• Entry is required (Content)
Correct invalid entries to continue
QUESTION : Please advise where I am wrong?
Thank you in advance for your help.
Bruno
Neil Beadle
Sounds like you have everything set up correctly.
The errors are indicating that you did not enter valid values in the 3 required fields.
Take a look at this How To to ensure that you are going through the correct procedure for adding content to PowerCMS.
powercms_creating_content.pdf
Post back and let us know where you end up.
