Validation not Triggered
Thread begun 7/19/2011 10:07 am by lr_leal239405 | Last modified 7/22/2011 2:03 pm by lr_leal239405 | 7274 views | 8 replies |
lr_leal239405
I applied server side validation to the credit card field on the Checkout form and tested it but it's not being triggered. I thought I followed the instructions correctly. What could I doing wrong? or is there a glitch I don't know about? I want to make sure it works before I proceed with all the rest. I've attached the checkout file. Thank you.
the checkout forms action is set to post to the confirm page:
<form name="ecart_checkout_form" action="confirm.php" method="post">
all form processing must occur on the forms action page
the work flow when using Server Validation when a form posts to the other page is:
On the forms action page, open the bindings panel, click the plus button and select Form Data. In the form data dialog click the folder icon and select the form page.
This adds dynamic data bindings to the bindings panel for the form.
now add the Server validation server behavior to the action page, make sure to set the failed redirect to go back to the form page.
back on the form page, add the error messages to show which fields have failed validation. Select the error message in design view, then add a Validation Show If Behavior (WebAssist -> Forms -> Validation -> Validation Show If)
in the validation show if, set the validation page to the forms action page, from the list of validations, select the validation that should trigger the error.
now select the form element, in the property inspector, click the lightning bolt next to initial value, expand the validated entries group and select the corresponding binding.
lr_leal239405
Data not retained
Thanks Jason. I followed your instructions and all the form validations work fine now. The only problem I have is that when it does redirect to the checkout form, all the data that was entered is gone.
You should be able to use the Dreamweaver Bindings panel to set the values of the form elements to the "Validated Field" value. This will make the form retain its original value after validation.
Give it a try and if it doesn't work attach a zipped copy of the form page and the page with the server validation applied and I'll take a look.
lr_leal239405
Bindings
Thanks....I got the bindings working and now it keeps all the data. The only ones I can't get it to keep is the data in the drop down menus. Any idea would be appreciated. Thank you.
Click the dynamic button in the select list properties panel. Then set the "initially selected" field to the validated entry just like what you did for the text fields.
lr_leal239405
Menu selected value bindings
That worked great....except for one. There's the expiration month that just won't stay. I don't know what the difference between this one and the other 3 menus is but this one keeps reverting back. I compared it to the expiration year and all the code on the field itself is same (except, of course, for the selection options). What could be causing that?
Possibly leading zeros? Perhaps the list has values like "07" and when it is stored php automatically truncates that to "7". Does it work if you choose December? That would support my hypothesis.
lr_leal239405
Validated Entries
Your hypothesis is correct. I left the display on the menu box with the 0's but removed the 0's from the posted values and now it works. Thanks.
