Surveyor SiteMap Hangs
Thread begun 11/05/2010 4:33 am by karen.marley367377 | Last modified 11/05/2010 4:16 pm by Dani Chankhour | 3607 views | 6 replies |
karen.marley367377
DW CS3 OP Windows Vista Ultimate
Whenever I use surveyor (1.08), create from site, surveyor hangs and does not produce the sitemap.xml.
Deleted wincache.
Reinstalled Surveyor
etc.
Help appreciated
Dani Chankhour
Can you send me a link to the site and i will try to reproduce the issue on my end.
karen.marley367377
Surveyor Hangs
www.proudlypresents.co.uk/
Dani Chankhour
i did a quick test and i was able to generate the site map, and i attached the xml file that got generated.
Try deleting your Dreamweaver Configuration folder, removing any extensions you have installed, reinstall Surveyor and see if you get the same result.
karen.marley367377
I cannot tell you how many times I have done this. but will try again...
karen.marley367377
did as suggested and same thing applies.
Dani Chankhour
Can you tell me what version and build number of Dreamweaver you are using?
