Date Format
Thread begun 10/25/2010 6:37 am by nmabey414064 | Last modified 10/29/2010 7:57 am by Jason Byrnes | 5466 views | 9 replies |
nmabey414064
Date Format
is it possible to use the chart in another date format than mm/dd/yyyy?
We are UK based and it would be ideal to send start end end date in dd/mm/yyyy.
Thanks for the help
you would need to edit the query created for the chart and use the MySQL Date_FORMAT command.
in the DynamicWebCharts/Data folder a file will be created named <pageName>_data1.php where <pageName> is the name of the page you applied the chart to.
this file has the recordset.
edit the recordset and add the DATE_FORMAT function around the date column:
DATE_FORMAT(dateColumn, '%d/%m/%Y')
nmabey414064
I am using ASP in VBscript and in the <pageName>_data1.asp is no date format function.
Where can I find this function in asp/vb?
Thanks very much for quick reply
in Access, it would be:
Format(dateColumn, 'dd/mm/YYYY')
nmabey414064
Sorry that might sound stupid...
But in which document can I change this?
My MsAccess database is using dd/mm/yyyy. The Graph doesn't display when I am sending dates in dd/mm/yyyy they need to be mm/dd/yyyy.
My
name_data1.asp,
name_dataparser1.asp,
wa_dfc_xmlVB.asp
nor wa_dwc.dtd
has a format date section.
So where do I change the format?
Thanks very much for all the help, I am new to this all and somethimes you can't the wood for the trees.
Thanks for all the help
ok this is the missing piece, how are you sending them in? through form? a query string?
can you sends a copy of the page that displays the graph and a copy of the data page, this may help me give you a better answer.
nmabey414064
I think it is through a query string...
I Query FD (FirstDay) and LD (LastDays) on the previous page like this (I set <%session.lcid=1033%> on the top of the page, so that the date is created in the american way, otherwise the graph is not displayed):
dim LD
dim FD
dim todaydate
todaydate = Day(date)
if RSD > todaydate then
FD = DateSerial(Year(Date), Month(Date) -2, RSD)
LD = DateSerial(Year(Date), Month(Date) -1, RSD -1)
else
FD = DateSerial(Year(Date), Month(Date) -1, RSD)
LD = DateSerial(Year(Date), Month(Date) -0, RSD -1)
end if
and then I pass them through a link and the url to the next page that displays the graph.
The url look then like this:
.../protected2.asp?Site_ID=5&Site_Name=Site%202&AM=4361&FD=9/15/2010&LD=10/14/2010
The code for the graph on the page displaying it is:
<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" width="940" height="200">
<param name="movie" value="DynamicWebCharts/open-flash-chart.swf?data=DynamicWebCharts/Data/protected2_dataparser1.asp?Site_ID=<%=Request.QueryString("Site_ID")%>%26FD=<%=Request.QueryString("FD")%>%26LD=<%=Request.QueryString("LD")%>" />
<param name="quality" value="high" />
<embed src="DynamicWebCharts/open-flash-chart.swf?data=DynamicWebCharts/Data/protected2_dataparser1.asp?Site_ID=<%=Request.QueryString("Site_ID")%>%26FD=<%=Request.QueryString("FD")%>%26LD=<%=Request.QueryString("LD")%>" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="940" height="200"></embed>
</object>
The code of the data page looks like this:
Dim MM_Stats14_STRING
MM_Stats14_STRING = "dsn=Login;"
Dim WADWCStats__ParamSite_ID
WADWCStats__ParamSite_ID = "-1"
If (Request.QueryString("Site_ID") <> "") Then
WADWCStats__ParamSite_ID = Request.QueryString("Site_ID")
End If
Dim WADWCStats__ParamFistDay
WADWCStats__ParamFistDay = "-1"
If (Request.QueryString("FD") <> "") Then
WADWCStats__ParamFistDay = Request.QueryString("FD")
End If
Dim WADWCStats__ParamLastDay
WADWCStats__ParamLastDay = "-1"
If (Request.QueryString("LD") <> "") Then
WADWCStats__ParamLastDay = Request.QueryString("LD")
End If
Dim WADWCStats
Dim WADWCStats_cmd
Dim WADWCStats_numRows
Set WADWCStats_cmd = Server.CreateObject ("ADODB.Command")
WADWCStats_cmd.ActiveConnection = MM_Stats14_STRING
WADWCStats_cmd.CommandText = "SELECT Stats_Date AS XLABEL, Minutes AS YVALUE FROM Stats WHERE Site_ID = " & Request.QueryString("Site_ID") & " AND Stats_Date >= #" & Request.QueryString("FD") & "# AND Stats_Date <= #" & Request.QueryString("LD") & "# ORDER BY Stats_Date"
WADWCStats_cmd.Prepared = true
Set WADWCStats = WADWCStats_cmd.Execute
WADWCStats_numRows = 0
Does that make sense, does this helps?
If I don't create the date in the american way and sent it in the uk way the graph doesn't display so I think I have to change somehow the way the graph wants to receive the date, but where?
Thanks very much for the help
add this code to the page that has the chart on it:
function switchMonthDay(theDate)
dim theMonth,theDay,theYear
theMonth = Left(theDate,inStr(theDate,"/")-1)
theYear = Right(theDate, Len(theDate) - inStrRev(theDate,"/"))
theDay = Mid(theDate,inStr(theDate,"/")+1, inStrRev(theDate,"/")-inStr(theDate,"/")-1)
switchMonthDay = theDay & " / " & theMonth & " / " & theYear
end Function
then locate these two code blocks:
<%=Request.QueryString(" FD")%>
and change them to:
<%=switchMonthDay(Request.QueryString(" FD"))%>
<%=switchMonthDay(Request.QueryString("LD"))%>
nmabey414064
Thanks very much it works!
you're welcome.
