Out of Memory again and again...
Thread begun 9/21/2010 10:50 am by Thom.Stanton415204 | Last modified 9/21/2010 1:37 pm by Jason Byrnes | 4892 views | 1 replies |
Thom.Stanton415204
Have tried everything suggested. Deleted file twice from ...Application Data\Adobe\Dreamweaver CS4\en_US\Configuration, restarted machine, restarted Dreamweaver.
Same issue keeps cropping up (previously during XML map creation, now in parsing for HTML version):
While executing onClick in WA_SurveyorHTML.htm, the following JavaScript error(s) occurred:
At line (usually 625) of file "C:\Program Files\Adobe\Adobe Dreamweaver CS4\Configuration\Shared\WebAssist\Surveyor\Library\WA_GeneralUI.js": out of memory
Line of code 625: else retStr = retStr.replace(/@@expandedstate@@/g, "");
I can be reached directly at 804-915-2449 or Thom.Stanton@VBMB.org.
Quick help is appreciated... I'm purchasing a competing app I've already used as a Try Out for comparison.
how large are is the site you are indexing? This problem can sometimes occur when indexing large site with many pages.
a possible work around is to add the pages manually instead of using the xml site map.
On the first step of the HTML site map wizard, select the "Select pages Manually" Option.
On the next page, click the plus button and select Get from File System, then select the root of your Dreamweaver site.
