Adjusting Items order (not using columns)
Thread begun 9/01/2010 1:04 am by Badger | Last modified 9/07/2010 11:27 am by Jason Byrnes | 1656 views | 3 replies |
Badger
What is the best way to change the order of a list not using an existing column. I understand the ORDER ASC/DESC sql but have seen other websites that allow a user to use up and down buttons to change a list order. Some WA user interfaces have the same function.
My current method is an order field in a table and to manually change the numbers to achieve the preferred order. Hardly dynamic. What would the sql/php look like to allow up and down buttons to move a row?
I'm thinking the up button subtracts the current order field by 1 and the order value of the field with the previous value adds 1. But don't know how to do this.
Also need some scripting as well
Note: The WA tutorial on order by different columns is not thje solution I'm looking for.
Any pointers?
have you seen this tutorial that Sojo Web created?
showthread.php?t=9353
Badger
That's it. Thanks Jason, I'll give this a try
sortable-rows-with-data-assist
you're welcome.
