Tutorial for AJAX Sortable Rows with Data Assist
Thread begun 1/21/2010 12:46 am by anonymous | Last modified 5/29/2015 4:07 pm by Ray Borduin | 43461 views | 82 replies |
anonymous
I posted this in the Announcements section but decided to put it here as well in case someone who would be looking for it later might miss it.
Here is the tutorial to make your DataAssist Results page Sort-able with Jquery/Ajax and then be able to save the new order.
blog_detail.php?id=16
Best regards,
Brian
toms016390756
This is awesome, nice job!
dlovas275157
Brian,
I have followed your tutorial at blog_detail.php?id=16
I'm very very close to getting this to work, but I think I have an error in my code on the process page.
Would you mind looking at my code (attached) and let me know what I am overlooking? Much appreciated, as I have been wanting to build sortable tables since ADDT died.
My paths to the js's are correct, so i know that is not the issue.
BTW- The tutorial is great! Thank you!
D.
dlovas275157
Attached is my database table, which may help as well.
I also realized my process page was missing
<?php require_once('../../Connections/connTEST.php'); ?>
So i added that connection include back in at the very top. Now everything runs as it should, BUT it does not save the re-order. Upon redirecting back to the results page, the records are in the old original order.
thnx again. d
anonymous
Hey d,
I will take a look this afternoon... sorry for the delay, I have been out of town for a few days.
Brian
anonymous
Originally Said By: dlovas275157
  Brian,
D.
D,
I found your issue... on the results page, you need to update the hidden field on about line 300... <input type="hidden" name="idorder[]" readonly="readonly" value="<?php echo($row_WADAstaff['ID']); ?>" />
It looks like you still have the variable that I used in my example when you pasted in the input... be sure to update it with the correct id from the table on your page and you should be all good to go.
Best regards,
Brian
dlovas275157
Brian,
Thanks so much for getting back to me. I apologize for taking so long to read your post, I had to move servers and have been swamped since the move.
I will look at it asap (probably early tomorrow).
Again, Thanks.
D.
Jaffa
Figured it out!
Thanks for the tut!
neo314
Hi All,
Thanks for that Brian. It really gave me a jump start on getting some functionality into WADA that I needed if I am to move away from ADDT.
I would like to build on what you offered. I have had this done for a couple of weeks now, but I have been to busy to get it posted.
This method only works if all the records are displayed (i.e. not with pagination), and it also won't work with any filtered recordsets like WADA Search or modifying the SQL of the results page which I will do a lot until WADA can manage based on recordsets.
I've worked out the details and wrapped it up in a class to minimize the number of edits required on the results page.
I'm afraid that I do not have the tutorial finished or the files up for download yet, but I will this week. In the meantime, my blog post (my first blog post) on the subject with a working demo is HERE (http://www.blazingimages.com/sortable-rows-with-data-assist) for anyone who wants to see. I would love any feedback.
BE SURE TO TRY FILTERING THE RECORDSET WITH THE FORM AT THE TOP OF THE DEMO TO SEE THAT WORK AS WELL.
neo314
I posted the files and instructions for use to my blog here: sortable-rows-with-data-assist
I hope someone find it useful. It is working for me so far.
