JavaScript error while applying Server Behaviour
Thread begun 7/29/2010 10:27 am by moodstyler | Last modified 7/30/2010 1:21 pm by Eric Mittman | 2459 views | 3 replies |
moodstyler
SuperSuite:
CookiesToolkit 3.1.3
System:
Mac OSX 10.5.8
Every time I try to insert a CookiesToolkit Server Behaviour it shows me this or a similar error message:
"While executing applyBehaviour in WA Cookie Redirect.htm, a JavaScript error occured. The action will not be added to your document."
I´ll have to say, that I already tried every offered solution on your site (delete the .dat file or deinstalling and reinstalling every extension), but still couldn´t get it to work!!!
To demonstrate it I put a video file here:
YzA4NWViN
I really hope you could help me, because without this extension …*– you know!
What is the version of DW you are working with? I know you have tried some of the common installation troubleshooting techniques but have you renamed the configuration folder and removed all the remaining extensions? Here are the steps for this if you have not already:
Let me know if this does not work for you and include your DW version so we can look into this issue further.
moodstyler
Sorry I forgot to write it and thanks for the quick response!
It´s Dreamweaver CS4
This Problem with the Javascript errors happened with different extensions from the first time on I installed them. So I´d followed once your intructions for troubleshooting but after the error on Cookies Toolkit still appeared. But for the most bugs it did help.
Yesterday I thought I take care of this Problem now and realized that there´s an update on CookiesToolkit to Version 3.1.3 and so I installed it, hoping to get relifed from this error – but still no luck :-(
If you have just updated the version 3.1.3 and are still getting the same result you may need to go and delete the cache file once again. If you do this and still have the same problem please let us know and I will open a ticket for you. I have tested this version of cookies on my Mac in CS4 and do not have the same result.
