file upload.
Thread begun 6/13/2010 1:48 am by i.edwards384429 | Last modified 6/18/2010 6:39 am by Jason Byrnes | 8333 views | 14 replies |
i.edwards384429
file upload.
Hi
Back against the wall for this project, got to get it on line within two weeks;-(
My initial problem is that I have used the solution pack to create a user registration sequence and I need to allow users to upload initially five photos.
I have the latest version of Universal email and I downloadedthe "adding digital file pro to dataassist insert pages..."
Below is exactly what I did and in what order but I fail at the instruction "from the Server behavious panel" double click on insert record" because I do nopt have that option listed.
Would appreciate any hints. (below is my sequence)
thanks
Ian
ON a site created using user registration module I need to allow the upload of images so I selected the page:
users_Profile.php
I selected the table.WAAATKTable and altered the number of rows to 16
I then opened my mysql database and added five fields called: UserImage1, userImage2 etc
the definition is varchar, length 20, decimals 0, allow null is ticked
Placed curser in the area I wanted image 1
on the form bar I selected the option file field
in the id field I typed UserImage1
and I left the label field empty
next I pressed OK.
I now have a field with a browse icon.
next I selected insert----webassist---file manipulation---upload
I left "1" as is apart from selecting web image
on the second menu I used the yellow folder icon to browse to and select the folder model_images which I created
previously. I selected the resize option fit width 500
Finaly I selected "finish"
Went to the Server behavious panel but I see no option for Insert Record.
Do you have DataAssist Installed? You will need DataAssist to edit the Insert record Behavior on the profile page.
Once you have installed DataAssist, you will be able to Double Click the Insert record server behavior.
You will need to bind each image column to the appropriate Server File name variable from the Uploaded Files (File Field Name) Group on the bindings panel.
i.edwards384429
update
Hi Jason
I do have dataassist installed and if I go to insert--webassist--dataassit --I see the wizard, the search wizard and the repeating table option.
However if I click on the server behavious panel I see no insert record to double click on. I do have an update record option to double click on but no insert record.
Where do I go form here
thanks
Ian
what page are you working with? The profile page? If it is the profile page, you need to edit the Update record Behavior.
i.edwards384429
SQL error
Hi
in my ongoing project I create a test website using the user registration solution.
Created the database and added one field called image which is varchar, length 100.
If I now open users_profile and add a file filed with the id image the image appears on the form.
SO far so good.
If I then double click on the server behavior update record I get the error
sql type not recognised: "
if I ok the error three times then I get the update record general configuration screen up.
The connection to the database is ok and I can register as a user and the data appears in the table
I have tried the usual deleting the Dw cache, deleting the database and reinstalling
Any ideas?
thanks
Ian
i.edwards384429
update
Hi
forgot to say
I've uninstalled digital download because I have universal emai installed.
When I look at server behaviours the email behaviour has a red exclamation and a note telling me it's anold version I double clicked to update to the latest version.
Might have no relavence but .....
cheers
Ian
i.edwards384429
update
Hi Jason
went back to basics listed below is exactly what I did step by step. End product is teh image is uploaded but the database is not updated.
I've clearly missed a step
would appreciate an assist
cheers
Ian
installed virgin database and core files.
Opened up page
exclamtion on Universal email [prior version]
Selected update Record (users) in the server behaviours field
Update record window opened normaly
Canceled out of that window.
Double clicked on the Universal email server behaviour
Create emial message opened.
Pressed finish
exclamtion mark against Universal email dissapears.
Double clicked on uPdate record server behaviour
That opened the update record wizard normally.
Went into the database using phpmyadmin
added a field:
type:varchar
length:100
0
allow null
default: NULL
Character set: latin1
Collation: latin1_swedish_ci
Saved and closed
went back to Dreamweaver and double clicked update record
Update record wizard opened OK
Added a row to the table.
Went to the form menu and added a file upload field with an id of UserImage1
Selected insert...webassist.....file manipulation---upload
selected:
trigger: any form post
file field: UserImage1
Action: overwrite
on next page:
for the upload folder I used the browse icon to select images/
the rest I left at the defaults.
Pressed finish.
Selected server behaviours update record
pressed next to go to next screen
SElected The colum named: userimage
pressed the lightning bolt to set value
was unable to see WA upload file but did find " upload files (UserImage1)
Opened this and found Server File Name- slected this and selected OK and finish
saved the file users_profile.php
opened in my local host
registered - data is written into the users table
then logged in to the users_Profile.php
used the browse button to select an image jpeg 70kb in size
pressed the update button
progress bar goes accross.
In the specified images folder is the image
but if I open the users table in phpmyadmin the userimage column is empty ie no path to the file.
i.edwards384429
update
Hi Jason
I have made some progress in that from the usersregistration I can now upload images.
The users profile is proving difficult.
This is waht I did
I first added a line to the table
and then inserted a text field.
I used ctrl T and changed the input type to hidden.
the code for this icon is :
<input type="hidden" name="textfield" id="textfield">
I placed my curser next to the hidden filed and added a form file field field with an ID of UserImage.
The selected insert---wa---file manipulation---file upload and set the default directory to images/ on page 2
Here's where I think I'm going wrong
I press the lightening bolt next to default file
I scrolled down to find the form field called texfield
Under WATKUpdateform I see listed the textfield whiuch I highlighted and clicked Ok
I then selected the behavior update record
selected userImage
and then clicked the lightening bolt to scroll down.
I see two entries
1.Uplod files global status
2. Upload files user image
I selected the second and highlighted
Server file name
Clicked OK
If I the preview and uplaod a file then the file uploaded with the sequence in User Registrationn is deleted and no mofified entry is added into the database. However the image is uploaded
Any ideas, I know it's me ;-)
thanks
Ian
send a copy of the profile page so I can examine the code, the steps sound correct, the code will tell the true story.
i.edwards384429
update
Hi Jason
been on this for two days ;-(
the code for the update page is in zip
hope you can see my error
thanks
Ian
