iRite Upload Double Quotes
Thread begun 5/21/2009 9:46 am by mike325598 | Last modified 9/15/2009 2:40 pm by Ray Borduin | 9611 views | 14 replies |
mike325598
I have uploading working within iRite. Once uploaded an I insert an image into the text area. I can add a border, select right justified to position the image.
When I insert, the image appears. Before submitting the form, the text appears as:
<img width="155" height="194" align="right" alt="" src="/userfiles/image/2009_Winner.jpg" />
After I submit, the content changes to:
<img width="&quot;155&quot;" height="&quot;194&quot;" align="&quot;right&quot;" alt="&quot;&quot;" src="&quot;/userfiles/image/2009_Winner.jpg&quot;" />
However, the inserts double quotes around everything. If I edit the image, an additional set of quotes appears. What could be inserting the extra set of quotes?
I'm using DataAssist to make the update.
Thank you
DataAssist added a function to encode the quotes so that it would work properly inside a regular form field.
Now you are using iRite and don't want the value encoded, so update the default value and remove the formatting function that is encoding the quotes. You will see it there in the default value and it should be easy to remove.
mike325598
I actually did this before checking back in and it fixed the problem. I kept getting an additional set of quotes after each submission. Thanks for your reply.
ss320646
inserting quotes
I have the same issue. I too have made the change as illustrated below.
My update initial field value is: <?php echo $row_WADApage_content['content']; ?>
This is the code I'm inserting.
<p><a href="#"><img height="71" width="222" alt="Appointment" src="images/appointment.gif" /></a></p><h3>
And this is the result.
<p><a href="&quot;#&quot;"><img height="&quot;71&quot;" width="&quot;222&quot;" src="&quot;images/appointment.gif&quot;" alt="&quot;Appointment&quot;" /></a></p><h3>
ss320646
Quotes
I have removed the formatting of the quotes. This is what I have.
// WebAssist iRite: Rich Text Editor for Dreamweaver
$WARichTextEditor_1 = CreateRichTextEditor ("content", "../WA_iRite/", "100%", "600px", "Custom", "../custom/page_content_Update_content4.js", "".$row_WADApage_content['content'] ."");
That should work now. Remove the double quotes added previously and it shouldn't add them any more.
ss320646
Quotes
It still adds them after the change.
I have created an incident so that somebody can look into this further with you. It appears it should be working, so somebody may have to help you debug the problem and when it occurs. Have you uploaded your files?
To view and respond to the incident go to: supporthistory.php
Paul
This post has been deleted.
