Problem with Administrative Back-End (Data Assist Tool)
Thread begun 3/26/2010 8:44 pm by Gabriel Tiviroli | Last modified 10/05/2010 7:09 am by gtocco81265659 | 6350 views | 7 replies |
Gabriel Tiviroli
Friends have a big problem, I trying to perform an administrative backend for a site-and though at the time of doing with Data Assist everything worked well, then, always following your instructions, I added the tools HTML Editor and File Upload (with Universal Mail 4), when viewing the pages generated had no problems, everything looks correct. But where did the tests of rigor, attempting, for example, insert a new record, I get the following error: (anyway, in attachment accompany the source code of the page):
Notice: Undefined offset: 6 in C:\wamp\www\Voz Noticias\WA_DataAssist\WA_AppBuilder_PHP.php on line 133
Notice: Undefined offset: 1 in C:\wamp\www\Voz Noticias\WA_DataAssist\WA_AppBuilder_PHP.php on line 135
Notice: Undefined offset: 2 in C:\wamp\www\Voz Noticias\WA_DataAssist\WA_AppBuilder_PHP.php on line 136
Notice: Undefined offset: 7 in C:\wamp\www\Voz Noticias\WA_DataAssist\WA_AppBuilder_PHP.php on line 133
Notice: Undefined offset: 8 in C:\wamp\www\Voz Noticias\WA_DataAssist\WA_AppBuilder_PHP.php on line 133
Notice: Undefined offset: 9 in C:\wamp\www\Voz Noticias\WA_DataAssist\WA_AppBuilder_PHP.php on line 133
Notice: Undefined offset: 10 in C:\wamp\www\Voz Noticias\WA_DataAssist\WA_AppBuilder_PHP.php on line 133
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ',4,1,)' at line 1
For any reason i can´t upload the files in this post!
Gabriel Tiviroli
More information about the errors.
I'm not sure if the attachments are up, two additional post I give you: php code and another: a database.
<?php require_once("../Connections/voznoticias.php"); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("../webassist/file_manipulation/helperphp.php"); ?>
<?php require_once('../Connections/voznoticias.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
$maxRows_WADADynListcategorias = 1000;
$pageNum_WADADynListcategorias = 0;
if (isset($_GET['pageNum_WADADynListcategorias'])) {
$pageNum_WADADynListcategorias = $_GET['pageNum_WADADynListcategorias'];
$startRow_WADADynListcategorias = $pageNum_WADADynListcategorias * $maxRows_WADADynListcategorias;
mysql_select_db($database_voznoticias, $voznoticias);
$query_WADADynListcategorias = "SELECT categoriaid, nombre_categoria FROM categorias ORDER BY categoriaid";
$query_limit_WADADynListcategorias = sprintf("%s LIMIT %d, %d", $query_WADADynListcategorias, $startRow_WADADynListcategorias, $maxRows_WADADynListcategorias);
$WADADynListcategorias = mysql_query($query_limit_WADADynListcategorias, $voznoticias) or die(mysql_error());
$row_WADADynListcategorias = mysql_fetch_assoc($WADADynListcategorias);
if (isset($_GET['totalRows_WADADynListcategorias'])) {
$totalRows_WADADynListcategorias = $_GET['totalRows_WADADynListcategorias'];
} else {
$all_WADADynListcategorias = mysql_query($query_WADADynListcategorias);
$totalRows_WADADynListcategorias = mysql_num_rows($all_WADADynListcategorias);
$totalPages_WADADynListcategorias = ceil($totalRows_WADADynListcategorias/$maxRows_WADADynListcategorias)-1;
$maxRows_WADADynListimportancia = 1000;
$pageNum_WADADynListimportancia = 0;
if (isset($_GET['pageNum_WADADynListimportancia'])) {
$pageNum_WADADynListimportancia = $_GET['pageNum_WADADynListimportancia'];
$startRow_WADADynListimportancia = $pageNum_WADADynListimportancia * $maxRows_WADADynListimportancia;
$query_WADADynListimportancia = "SELECT importanciaid, importancia_valor1 FROM importancia ORDER BY importanciaid";
$query_limit_WADADynListimportancia = sprintf("%s LIMIT %d, %d", $query_WADADynListimportancia, $startRow_WADADynListimportancia, $maxRows_WADADynListimportancia);
$WADADynListimportancia = mysql_query($query_limit_WADADynListimportancia, $voznoticias) or die(mysql_error());
$row_WADADynListimportancia = mysql_fetch_assoc($WADADynListimportancia);
if (isset($_GET['totalRows_WADADynListimportancia'])) {
$totalRows_WADADynListimportancia = $_GET['totalRows_WADADynListimportancia'];
} else {
$all_WADADynListimportancia = mysql_query($query_WADADynListimportancia);
$totalRows_WADADynListimportancia = mysql_num_rows($all_WADADynListimportancia);
$totalPages_WADADynListimportancia = ceil($totalRows_WADADynListimportancia/$maxRows_WADADynListimportancia)-1;
$maxRows_WADADynListpaneles = 1000;
$pageNum_WADADynListpaneles = 0;
if (isset($_GET['pageNum_WADADynListpaneles'])) {
$pageNum_WADADynListpaneles = $_GET['pageNum_WADADynListpaneles'];
$startRow_WADADynListpaneles = $pageNum_WADADynListpaneles * $maxRows_WADADynListpaneles;
$query_WADADynListpaneles = "SELECT panelid, panel1 FROM paneles ORDER BY panelid";
$query_limit_WADADynListpaneles = sprintf("%s LIMIT %d, %d", $query_WADADynListpaneles, $startRow_WADADynListpaneles, $maxRows_WADADynListpaneles);
$WADADynListpaneles = mysql_query($query_limit_WADADynListpaneles, $voznoticias) or die(mysql_error());
$row_WADADynListpaneles = mysql_fetch_assoc($WADADynListpaneles);
if (isset($_GET['totalRows_WADADynListpaneles'])) {
$totalRows_WADADynListpaneles = $_GET['totalRows_WADADynListpaneles'];
} else {
$all_WADADynListpaneles = mysql_query($query_WADADynListpaneles);
$totalRows_WADADynListpaneles = mysql_num_rows($all_WADADynListpaneles);
$totalPages_WADADynListpaneles = ceil($totalRows_WADADynListpaneles/$maxRows_WADADynListpaneles)-1;?>
// WA_UploadResult1_1 Start
'UploadFolder' => "../images/fotosnoticias/lg/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "120",
'ResizeHeight' => "120",
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End?>
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
'UploadFolder' => "../images/fotosnoticias/tn/",
// WA_UploadResult2_1 End
// WA_UploadResult2_2 Start
$WA_UploadResult2_Params["WA_UploadResult2_2"] = array(
'UploadFolder' => "../images/fotosnoticias/tn/tnlistados/",
'ResizeType' => "1",
'ResizeWidth' => "180",
'ResizeHeight' => "90",
// WA_UploadResult2_2 End
// WA_UploadResult2 Params End
if(isset($_POST["Insert_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "imagen_grande", "0", "", "JPG:90", $WA_UploadResult1_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult2");
WA_DFP_UploadFiles("WA_UploadResult2", "imagen_chica", "0", "", "JPG:90", $WA_UploadResult2_Params);
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $voznoticias;
$WA_table = "noticias";
$WA_sessionName = "WADA_Insert_noticias";
$WA_redirectURL = "noticias_Detail.php";
$WA_keepQueryString = false;
$WA_indexField = "noticiaid";
$WA_fieldNamesStr = "titulo|fecha|hora|piedefoto|resumen|desarrollo|imagen_grande|imagen_chica|categoriaid|importanciaid|panel";
$WA_fieldValuesStr = "".((isset($_POST["titulo"]))?$_POST["titulo"]:"") ."" . "|" . "".((isset($_POST["fecha"]))?$_POST["fecha"]:"") ."" . "|" . "".((isset($_POST["hora"]))?$_POST["hora"]:"") ."" . "|" . "".((isset($_POST["piedefoto"]))?$_POST["piedefoto"]:"") ."" . "|" . "".((isset($_POST["resumen"]))?$_POST["resumen"]:"") ."" . "|" . "".((isset($_POST["desarrollo"]))?$_POST["desarrollo"]:"") ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."" . "|" . "".((isset($_POST["categoriaid"]))?$_POST["categoriaid"]:"") ."" . "|" . "".((isset($_POST["importanciaid"]))?$_POST["importanciaid"]:"") ."" . "|" . "".((isset($_POST["panel"]))?$_POST["panel"]:"") ."";
$WA_columnTypesStr = "none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL";
$WA_connectionDB = $database_voznoticias;
if ($WA_redirectURL != "") {
Gabriel Tiviroli
More information about the errors: Data Base
CREATE TABLE IF NOT EXISTS `categorias` (
`categoriaid` int(11) NOT NULL AUTO_INCREMENT,
`nombre_categoria` varchar(150) NOT NULL,
PRIMARY KEY (`categoriaid`)
) ENGINE=InnoDB DEFAULT CHARSET=latin1 AUTO_INCREMENT=12 ;
-- Volcar la base de datos para la tabla `categorias`
INSERT INTO `categorias` (`categoriaid`, `nombre_categoria`) VALUES
(1, 'economia'),
(2, 'deportes'),
(3, 'policiales'),
(4, 'sociedad'),
(5, 'mundo'),
(6, 'entretenimiento'),
(7, 'opinion'),
(8, 'entrevistas'),
(9, 'sociales'),
(10, 'politica'),
(11, 'regionales');
-- Estructura de tabla para la tabla `importancia`
CREATE TABLE IF NOT EXISTS `importancia` (
`importanciaid` int(11) NOT NULL AUTO_INCREMENT,
`importancia_valor1` int(11) NOT NULL,
PRIMARY KEY (`importanciaid`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1 AUTO_INCREMENT=6 ;
-- Volcar la base de datos para la tabla `importancia`
INSERT INTO `importancia` (`importanciaid`, `importancia_valor1`) VALUES
(1, 1),
(2, 2),
(3, 3),
(4, 4),
(5, 5);
-- Estructura de tabla para la tabla `noticias`
CREATE TABLE IF NOT EXISTS `noticias` (
`noticiaid` int(11) NOT NULL AUTO_INCREMENT,
`titulo` varchar(150) NOT NULL,
`fecha` varchar(45) NOT NULL,
`hora` varchar(15) NOT NULL,
`piedefoto` varchar(150) NOT NULL,
`resumen` varchar(200) NOT NULL,
`desarrollo` longtext NOT NULL,
`imagen_grande` varchar(150) NOT NULL,
`imagen_chica` varchar(150) NOT NULL,
`categoriaid` int(11) NOT NULL,
`importanciaid` int(11) NOT NULL,
`panel` int(11) NOT NULL,
`logotitulo` varchar(150) NOT NULL,
PRIMARY KEY (`noticiaid`)
) ENGINE=InnoDB DEFAULT CHARSET=latin1 AUTO_INCREMENT=13 ;
-- Volcar la base de datos para la tabla `noticias`
INSERT INTO `noticias` (`noticiaid`, `titulo`, `fecha`, `hora`, `piedefoto`, `resumen`, `desarrollo`, `imagen_grande`, `imagen_chica`, `categoriaid`, `importanciaid`, `panel`, `logotitulo`) VALUES
(1, 'Mas testimonios desde el miedo y el dolor: como vivio el terremoto un mendocino', '1 de Marzo de 2010 ', '10:40', 'Olivares viajo a Chile a esparcir las cenizas de s', '", cerró la rubia.', 'farro.jpg', farro.jpg', 6, 3, 0, 'entretenimiento.png');
-- Estructura de tabla para la tabla `noticiasregionales`
CREATE TABLE IF NOT EXISTS `noticiasregionales` (
`noticiaregionalid` int(11) NOT NULL AUTO_INCREMENT,
`titulo` varchar(200) NOT NULL,
`piedefoto` varchar(100) NOT NULL,
PRIMARY KEY (`noticiaregionalid`)
) ENGINE=InnoDB DEFAULT CHARSET=latin1 AUTO_INCREMENT=4 ;
-- Volcar la base de datos para la tabla `noticiasregionales`
INSERT INTO `noticiasregionales` (`noticiaregionalid`, `titulo`, `fecha`, `hora`, `piedefoto`, `resumen`, `desarrollo`, `imagen_grande`, `imagen_chica`, `categoriaid`, `importanciaid`, `panel`, `logotitulo`) VALUES
(1, 'Los profesionales de la salud anunciaron un paro para la semana que viene', '10 de marzo de 2010', '17:50', 'La Voz Noticias', '.', 'default.jpg', '', 4, 1, 0, 'regionales-sociedad.png');
-- Estructura de tabla para la tabla `opinion`
CREATE TABLE IF NOT EXISTS `opinion` (
`opinionid` int(11) NOT NULL AUTO_INCREMENT,
`periodista` varchar(150) NOT NULL,
`nota_resumen` varchar(200) NOT NULL,
`nota` longtext NOT NULL,
`fecha` varchar(50) NOT NULL,
`imagen_url` varchar(150) NOT NULL,
PRIMARY KEY (`opinionid`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1 AUTO_INCREMENT=2 ;
-- Volcar la base de datos para la tabla `opinion`
INSERT INTO `opinion` (`opinionid`, `periodista`, `titulo`, `nota_resumen`, `nota`, `fecha`, `imagen_url`) VALUES
(1, 'Daniel Paglialuco', 'UN TIPO DE POLITICO', '. ', '15 de marzo de 2010', 'columnista1.jpg');
-- Estructura de tabla para la tabla `paneles`
CREATE TABLE IF NOT EXISTS `paneles` (
`panelid` int(11) NOT NULL AUTO_INCREMENT,
`panel1` int(11) NOT NULL,
PRIMARY KEY (`panelid`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1 AUTO_INCREMENT=4 ;
-- Volcar la base de datos para la tabla `paneles`
INSERT INTO `paneles` (`panelid`, `panel1`) VALUES
(1, 1),
(2, 2),
(3, 3);
-- Estructura de tabla para la tabla `usuarios`
CREATE TABLE IF NOT EXISTS `usuarios` (
`usuarioid` int(11) NOT NULL AUTO_INCREMENT,
`nombredeusuario` varchar(15) NOT NULL,
`password` varchar(10) NOT NULL,
`email` varchar(250) NOT NULL,
PRIMARY KEY (`usuarioid`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1 AUTO_INCREMENT=3 ;
-- Volcar la base de datos para la tabla `usuarios`
INSERT INTO `usuarios` (`usuarioid`, `nombredeusuario`, `password`, `email`) VALUES
(1, 'gabytivi', '02304022', 'webmaster@gabrieltiviroli.com'),
(2, 'dani', '02304022', 'danielgutierrez@lavoznoticias.com');
can you compress the PHP page into a zip archive and attach the zip file to your reply so I can see the entire page, including the form.
Gabriel Tiviroli
PHP Zip File with php pages!
here is the attachment!
Gabriel Tiviroli
Please, answer to me!
Ey! guys! please, answer to me! thanks!
Please see our Support Policy and hours here:
showthread.php?t=11650#
we offer a 1 to 2 business day response time.
some of the columns do not have a data type set in the insert record behavior.
open the server behaviors list, Window -> Server Behaviors. On the second step, make sure that the Type column does not say Undefined for any of the columns, If it does, you will need to select the appropriate type for that column.
gtocco81265659
Where can I find a list of type for data assist... ?
Solved from Behaviors Panel,
but... why data assist don't find a simple varchar type on a Mysql DB?...
Is not very good update manually yet...
