dataAssist Wizzard and Dreamweaver crash !!!!
Thread begun 3/19/2010 10:32 am by thomas.ballarin285351 | Last modified 4/16/2010 8:19 am by Jason Byrnes | 5289 views | 8 replies |
I have a problem with dataAssist 2.0.6 when I use dataAssist Wizzard. Dreamweaver CS4 crash all the time. I can't use dataAssist.
I remove the cache file and I delete Config folder of Dreamweaver and I restart my Mac...
The problem persit... Just detail page is created...
I'm very disapointed !!!
Please help me ?
Thanks in advance...
Thomas
To help us understand your set up, can you post a couple of screen shoots?
One showing the Testing server settings in your site definition, and others showing how you are configuring the DataAssist Wizard
Please crop the screen shots to only include the necessary information so they will be readable when uploaded.
Also if you could include a screen shoot showing your database table layout.
Hi Jason,
When I use DataAssist Wizard form Insert panel, Dreamweaver crash when I click finish...
My info of configuration :
Evaluation server : /Applications/MAMP/htdocs/ozalead
Server model : PHP MySQL
Access : Local/Reseau
Code SQL of my table :
SET NAMES latin1;
SET FOREIGN_KEY_CHECKS = 0;
CREATE TABLE `articles` (
`id_article` int(11) NOT NULL,
`nom_article` varchar(255) NOT NULL,
`date_article` varchar(255) NOT NULL,
`texte_article` varchar(255) NOT NULL,
`publication_article` datetime NOT NULL,
`etat_article` tinyint(4) NOT NULL,
`comment_article` varchar(255) NOT NULL,
PRIMARY KEY (`id_article`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1;
SET FOREIGN_KEY_CHECKS = 1;
Only this files are created :
- page_Results.php
- WADbSearch (folder)
- WA_DataAssist (folder)
I uninstall DataAssist Extension, remove MacFilecache and Configuration folder... I restart my mac...
But the problem persist !!!!
Please help me !!!
Sorry for my bad english !!!
Regards,
Thomas
I have created a support ticket for you so that we can look into the issue further. To view and update your support ticket, please log into your support history:
forums/
diagnostic report of Dreamweaver crash
I reinstall DW but the same problem persist...
In attach file, there is diagnostic report of Dreamweaver crash...
Please help me !!! ;-)
T.B
I have updated your incident asking for contact information. Please continue working on this issue in our support incident section instead of the forums, since it appears we will need to contact you directly in order to debug this issue.
anonymous
Crashing Possible Solution
Hi All
I'm fairly new to this but I had the same issue when my dynamic pages were freezing and crashing. After research I found an article that said to do the following:-
Locate the WinFileCache file in c: User /"your name"/appdata/roaming/adobe/dreamweaver Configeraton
Rename the winFileCache ie BackupWinFileCache ( Just in case doesnt work for you) with this absent a new one is created.
My Dreamweaver data assist works a treat now -- I have seen other suffering with this and it worked for them also! Realy do hope it does some good!
Tony
reneas.email303886
DAW Locks Up on Final Step!
I have tried the some of the tips on renaming files, etc. nothing has worked. I need to know the solution preventing DAW from locking up on my machine running Windows 7 and DW CS4 asap. I have project deadlines and this is a major set back!!
Best,
Renea
login.php
