Help with search syntax please
Thread begun 2/09/2010 7:35 am by David CHnet.com | Last modified 2/10/2010 10:36 am by Eric Mittman | 959 views | 1 replies |
David CHnet.com
I don't understand how to change this line of code ...
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["descriptionSearch"]))?" ".$_POST["descriptionSearch"]." ":"") ."","AND","Includes",",%20","|%20","%22","%22",0);
I'd love to see the syntax for this documented somewhere.
Anyway, my problem is this. descriptionSearch won't show me anything that has a full stop next to it. eg: it will find the word "service", but not the word "service." I have tried loads of ideas but I either break it or ... break it.
Can someone help please - urgent!!!
THANKS
This code is the result of applying the DataAssist Search server behavior. All of the parameters that you see in this function call are configured in the DataAssist Search wizard.
In order, you are seeing the type of search, the value used, the separator, the comparison, the AND character, then the OR character, the start and end characters then the field type.
There should be no need to manually edit this as you can make the changes directly in the server behavior. I did a sample test using a keyword type of search using the includes comparison and I was able to search for a column that had a . character in the value and get back that value without issue. Here are some of the search terms used and the results returned in my test:
search for ca. returns ca.r
search for this. returns this. is. a sentence with some. periods
If you could post back with a table in a sql file that has some sample records in it I would be glad to do some tests to see what the problem may be.
