Form display help please
Thread begun 2/04/2010 9:45 am by mail281376 | Last modified 2/04/2010 11:25 am by mail281376 | 1998 views | 2 replies |
mail281376
integrated contact form solution pack into webpage ok but have a problem with validation fields and error message appearing as text beside fields.Form can be viewed here contactus.php. Form and captcha working fine and receiving emails on test sending of form but how do I alter form so that it shows the correct message beside the fields at the right time?
Any help greatly appreciated.
neilo
Hiya,
Make sure that you have all of the necessay elements of the original 'contactus.php' file in the right places in your own page.
&#8226; Everything above the '<!DOCTYPE html . . . >' line in the original file must be placed above the '<!DOCTYPE html . . . >' line in your own page.
&#8226; Both of the SpryAssets '<script src=""""> </script>' lines must be in the head area of your page.
&#8226; Both of the SpryAssets '<link href="" rel="stylesheet" type="text/css" />' lines must be in the head area of your page.
&#8226; The form inside your bady tags wherever you want it.
&#8226; At the bottom of your page, just befor the closing </body> tag, should be the five spry validation lines from the original :
<script type="text/javascript">'
var sprytextfield1 =
var sprytextfield2 =
var sprytextarea1 =
var sprytextfield3 =
var sprytextfield4 =
</script>
Check that these are all in place in your page, and that the files linked to from your page are in the right relative locations on your server.
mail281376
Neilo- many thanks
Hi neilo, thanks very much for your reply. The code was missing in the page. After adding it to page as suggested all works fine now. Thanks again for your response.
