Upgrading a site to V2.0
Thread began 1/29/2010 10:56 am by paul.urgero235355 | Last modified 1/29/2010 3:01 pm by Dani Chankhour | 878 views | 3 replies |
Paul
I have v1.02 on one site, and v2.0 on another. The admin interface on v2.0 is much easier. How would I upgrade the v1.02 to v2? Would it simply be replacing the pages and the images?
Also, is there a way that my customer can just receive the order without a payment method having to be processed?
Paul
Dani Chankhour
The problem is the database integration. the database for Powerstore v1 is different than powerstore v2, so you will run into a lot of issues with that.
In powerstore v2, you could disable going through a gateway, you just need to set this variable to true:
$WAGLOBAL_Test_Mode = true;
Paul
Well, I haven't started uploading product to the database...so I can start from scratch...but can I use the images that I've already made for v1.0?
Thanks!
Dani Chankhour
You won't be able to use the images from V1 and since you don't have any products, i recommend that you start with V2 instead of going from v1 to v2.
But if you decided to go with the update then i recommend that you replace your V1 database to a v2 database by running the v2 sql file, and then you could just copy the admin folder from v2 to v1 and then you need to copy the admin.css from v2 to v1. there is probably going to be missing images, so you will need to copy v2 images folder to v1 as well.
But remember that v2 admin section have added functionality that won't show on the front pages, such as options and the added gateway and added shipping.
