Attribute Optinos for Products
Thread begun 1/27/2010 5:02 pm by JLK | Last modified 2/09/2010 1:50 pm by Eric Mittman | 2346 views | 4 replies |
JLK
Please advise how I can use eCart5 (or other software in the library I've subscribed to) to add products to your cart function where the customer has to choose options of the product (size and color) AND have the appropriate product added to the cart.
thank you
Before you can add options to your cart you will need to add columns for each of the options you would like to record. To get product options to add to the cart you can just add in a regular add to cart button on the page.
You could then add in your select lists for the size and for the color to the form. Once you add in the select lists you would then update the add to cart server behavior and bind the correspond cart columns with these new select lists.
web_assist_mail157665
Where is the documentation for this ecart5 feature please?
crispin
Options documentation a good idea!
I would also like to know a good step by step guide on how to do this.. even if it is just simple bullet points.. it is an important part of ecommerce as almost all products have some kind of option.
It looks like you had another thread that Jason responded to with some info on this, here is a link to the thread for any others that are interested:
showthread.php?t=9972
