Site Assist Professional freezing up
Thread begun 1/25/2010 11:11 am by tolushayoo193471 | Last modified 1/26/2010 2:22 pm by Jimmy Wu | 2803 views | 5 replies |
tolushayoo193471
Am trying to use Site Assist Professional to build new pages using my dreamweaver template, so from layout I select define, then new, then under dreamweaver template I select my template and for the next 20 minute it was just there frozzen, I close dreamweaver then started all over again and it crashes again without building he site.
Am using Dreamweaver CS3, Site Assist Professional . please find the attached print screen
thanks
Jimmy Wu
Are you able to generate pages if you don't use your template? If that works, could you please send me your template so I can give it a try as well?
tolushayoo193471
yes, the page will be generated without my own template. please find the attached
Jimmy Wu
It looks like this template only has one editable region, which will not work for SiteAssist Pro. You will have to have more than one editable region: menu, content and footer.
I am able to get past the screen you posted a screen shot of. What operating system are you on and what version of the extension are you running?
tolushayoo193471
Am running the latest version of the extention. Am using Vista.
I dont think I agree with you regarding the 3 editable region. Why? becasue the template that was generated by site Assit pro itself only have 1 editable region which is the content area.
Jimmy Wu
Thanks for pointing that out. I have logged it as a bug and it should be fixed for a future release.
You do need more than one editable region to create SiteAssist Professional layouts using a template though.
Does the interface freeze if you use other templates as well or is it specific to this template?
