E CArt or Powerstore
Thread begun 1/24/2010 11:39 pm by J7HNW | Last modified 1/25/2010 11:35 pm by J7HNW | 2931 views | 5 replies |
J7HNW
Please help. I have E Cart 4 for ASP
I have a relativey simple 20 item cart to do. Now all extensions are PHP - please advise the best solution. I can upgrade E Cart or get Powerstore. As I know nothing abut PHP - I see powerstore is "out of the box " ready to go.
Can this be said about E Cart 5 - ie does it have a Setup wizard to the SQL database for storing orders etc like Powerstore - or will this have to be hand coded ?
I feel although I only know ASP that it would be easier to buy powerstore - but for the future - it may be better to upgrade my e cart.
Please can you advise me on this ?
Thank you
John
you can use the sample eCommerce database:
ecommerce-database/
The checkout wizard in eCart 5 has a preset for order management to automatically set up for this database. If you choose to use another database, eCart can automatically create the needed Orders and Order Details tables.
J7HNW
Another query
Thanks Jason
Iam only used to working with an Access Database and ASP pages. Can E Cart 5 attach itself to an Access Database for data - and then store using the wizard all orders into the SQL database ?
As I have no knowledge of PHP otherwise I cannot set up product lists and details on the Website - Ahead of the Cart.
I have made carts before which are on the ASP version wihout any issues - but since you went PHP I am concerned as to what is possible with the new E Cart
Can I still usethe Access database storing data ?
John
eCart does not support using an Access database, only the MySQL Database.
The sample eCommerce database I linked to above contains all of the tables you will need including the Products table.
Office Guy-172461
Originally Said By: J7HNW
I would recommend:
The Database Starter Kit for PHP (It's free)
database-for-php/
J7HNW
Thank You
Thanks for your help - I may just stick with E Cart 4 until learn enough about PHP
