eCart Confirmation Page question
Thread began 1/21/2010 12:55 pm by ryanteets270615 | Last modified 1/22/2010 11:38 am by Eric Mittman | 643 views | 1 replies |
ryanteets270615
Why does the confirmation page that is created by eCart use Hidden form fields to bind the Session variables that are used in the Save to Database behaviour? Couldn't the Session variables be bound directly to the Save to Database function without using the hidden form elements?
What advantage do you get by using the hidden form elements?
What is being done by using the hidden form elements is that you are mimicking the interaction of the checkout page with the confirm page. Since the checkout page posts the form elements to the confirm page this page has been setup to work with the posted form element values. To keep this continuous hidden form elements are added and set to the values of the formerly posted elements. This way things like the validations will still occur and any references to the values on this page can use the posted values weather the values come from the checkout or the confirm page.
