Product Results Page
Thread begun 1/13/2010 10:48 am by toby379423 | Last modified 1/22/2010 2:30 pm by Eric Mittman | 2824 views | 3 replies |
toby379423
Hi there,
I wanted to change the Product List page and make the "Learn More" button on the right to the "Add To Cart" button instead of going to the Products Detail page. How would I go about doing that?
Here is the page in question:
Products_Results.php?Search=0
Thanks in advance!
One other thing I wanted to do was, on the Continue Shopping button on the cart.php page, I would like it to go to the home (index.php) page instead of back to the previous item. Is this possible?
You could make these changes but if you do this you will loose the ability to have the product options when you add the item to the cart.
To get it workign like this would require you to make use of eCart to add in the add to cart functionality to this page. Once added you could update the button to be the same as the one on the details page. This will allow you to add the item to the cart from the listing page.
As for the continue shopping button you can make it always go to any page in the site you would like by editing the code. You can use eCart to alter the continue shopping server behavior that is applied and just specify the redirect in there and uncheck the box to go to previous URL.
toby379423
Now when I try to add the Add To Cart button, i get this error message in Dreamweaver:
"While executing onClick in WA eCart AddToCart.htm, the following JavaScript error(s) occurred:
At line 924 of file "1TB:Applications:Adobe Dreamweaver CS4:Configuration:Commands:WA eCart AddToCart.js":
document.generalWP.document.column.options[document.generalWP.document.column.selectedIndex] has no properties"
Any idea what this is, and more importantly, how to fix this to put an Add To Cart button?
JS errors like this can occur from time to time. Usually you can get pat this problem by deleting the cache file for DW. Here is a link to a document that lists the steps to take for this:
If this does not work for you there may be an issue with the configuration folder. You can rename this to undo any corruption that may have occurred. Here is a link to a post with steps you can take to do this if need be.
showpost.php?p=12293&postcount=2
