No email sent when submitting form...
Thread begun 1/12/2010 10:10 pm by Stevebo | Last modified 1/12/2010 10:39 pm by Stevebo | 2009 views | 1 replies |
Stevebo
I have a profile form for a user where I insert a record (using DA) based on the submit button being pressed after they fill in their info. I do not have a go to location set for anything, then I added another server behavior using DA to update the record with an encrypted password that I generated using SA, and it too does not have a go to location set. Then I use UE to send an email containing a password that I generated (per the SA video on sending a password). I set the go to location to a welcome.php file in UE.
I have hard-coded the To address and have supplied a from email address as well. I used the unencrypted password stored in a session variable in the message body so I can see what was generated.
When I submit the form, it does the insert, it updates the record with the encrypted password, and I go to the welcome.php page, but the email never arrives.
I created a second form to ensure UE is working OK and I just submit the contents of a simple form which is captured in UE and it sends everything just fine.
Any ideas why UE won't send the email for my profile form yet it will insert the record, update the password OK and display the welcome.php page which is set in UE? It appears to be going to the right page after UE runs its course, but no email is ever sent. The UE code is last in the code view.
steve
steve
Stevebo
This post has been deleted.
Stevebo
Turns out that what was causing the problem appeared to be an errant session variable. I had put two of them in the body of the email. One was the generated password, the other was the user's email address that I was pulling from the form. For some reason the user's email address was causing the problem such that UE wouldn't send the email.
I discovered this problem by deleting any of the dynamic values from the body of the email and then running the process of entering form data and submitting it. Sure enough, i got an email albeit without the dynamic values. Then I added just the password and it would send OK. Then I added the email address session variable and it failed.
So I guess it's working OK, I must have done something wrong with the session variable.
steve
