1.0.2 not redirecting or sending
Thread begun 1/11/2010 10:55 am by iggymak198560 | Last modified 1/13/2010 9:50 am by Jason Byrnes | 3649 views | 5 replies |
iggymak198560
Hi, I read through all the posts I could find that hinted at a similar problem, including one of mine from long ago, but I'm still stuck. Apologies if I missed one with an answer... I also set up a ticket with the host but I feel you all can help better.
Page in question is here contactgch.php
Globals is currently at standard re email server, i.e. blank.
I'm getting these warnings (need to view source to see them as they get covered up):
Warning: mail() [function.mail]: Failed to connect to mailserver at 192.168.1.67 port 25, verify your "SMTP" and "smtp_port" setting in php.ini or use ini_set() in C:\Domains\greenwichcolonhydrotherapy.com\wwwroot\ContactForm_GMC\WA_Universal_Email\mail_PHP.php on line 254
Warning: Cannot modify header information - headers already sent by (output started at C:\Domains\greenwichcolonhydrotherapy.com\wwwroot\ContactForm_GMC\WA_Universal_Email\mail_PHP.php:254) in C:\Domains\greenwichcolonhydrotherapy.com\wwwroot\ContactForm_GMC\contactgch.php on line 35
I did find one whitespace space and removed it but it didn't change anything.
There was a thread with these two lines mentioned but the dude just said the host fixed it...
The validation works well or seems to.
Can you see anything my still noobie brain is missing? Should I wait to see what the host says?
The site is on accuwebhosting.com on a Windows starter package that is supposed to support PHP 4 and 5 if that helps.
Thank you!
The first error is the cause of the second error.
The first error:
is saying that the SMTP server you entered "192.168.1.67" is not valid you will need to contact your host to determine the correct smtp server address to use.
iggymak198560
will try that out...
I left it blank in WA-global, though... I did write them, they're not as quick as you guys I see :) I'll make another ticket there!
Thank you!
If you leave it blank in the WA_Globals.php file, it will use the setting from the php.ini file. The php.ini file must be set to use 192.168.1.67 as the SMTP server.
iggymak198560
fixed!
yes, I feel silly :)
now to rebuild my PowerStore job from the dead workstation...
No worries.
