Newbie question: how to edit after creating site
Thread begun 1/08/2010 1:00 pm by sjurick372352 | Last modified 1/21/2010 11:57 am by Jimmy Wu | 3447 views | 5 replies |
sjurick372352
Hi. I've just created a test site using Site Pro. Published to test server. Everything is working.
But let's say now I want to change the menus and use Menu Writer or change the overall theme b/c the client doesn't like the layout or colors?. How do I do that once the site has been created?
Jimmy Wu
Under the site menu you can go to the menu item Modify SiteAssist Professional Site and you will be able to make these changes.
sjurick372352
OK, so I've got a few more questions:
1) If I create a site with SAP, how do I change the menu using CCS Menu Writer?
2) How can I import the downloaded templates from the WA site to see how they would look in the SAP building interface? This goes for both CCS Menu Writer and Web templates
Jimmy Wu
To edit the menu using CSS menu writer, you will have to select the menu and in the properties inspector select edit menu. This may also help you with customizing your menus:
siteassistpro_update_sculptor_mw_ht.pdf
To import menu items or SiteAssist Pro layouts, you will have to go into the Insert->WebAssist->Preset Manager and select the correct option from the drop down menu. Then click Import and select the file that you want to import.
Make sure you take a look at the guides and tutorials on the support page, which will help you get started on using the products:
siteassist/
htm211248644
Did this chnage for Dreamweaver CS4?
Originally Said By: Jimmy Wu
I cannot find the edit menu button in the properties inspector of Dreamweaver CS4. Did this option change for editing the menu?
Jimmy Wu
No, the option should appear when the menu is selected. What you can do is to go into the Dreamweaver Preferences and go to the Invisible Elements section and make sure that Scripts checkbox is selected.
If this is selected, then you can click on the script tag and the edit buttons should appear in the properties inspector.
