Gallery not showing on production server
Thread begun 1/08/2010 9:23 am by kbettenc296716 | Last modified 1/15/2010 1:03 pm by kbettenc296716 | 3130 views | 6 replies |
kbettenc296716
I have uploaded every power gallery file from my local server (I hope), did the install on production, added a gallery and added 18 images, choose a design and I added the php code to the mixedmedia.php page, and uploaded that page.
mixedmedia.php
All I get is this:
First Prev Next Last
loading...
If I add the link provided in "Use this URL when linking to your PowerGallery from any web page:" It can't find the page.
The link is on index.php
at the end of the left column of text.
The admin login information is in the attached file.
in the galleries/global.php file, try adding the following at line 2:
unset($_SERVER['DOCUMENT_ROOT']);
then locate the following code:
$pg_config = array(
    'path' => str_replace('galleries/', '', str_ireplace(str_ireplace('\\', '/', realpath($_SERVER['DOCUMENT_ROOT'])), '', $abs_prefix)),
    'html_prefix' => str_ireplace(str_ireplace('\\', '/', realpath($_SERVER['DOCUMENT_ROOT'])), '', $abs_file) . '/'
kbettenc296716
You say
"find the following code"
$pg_config = array(
But, you don't tell me what to do with it.
Do I add this to the global.php file? If so, where?
I looked for that exact string on the whole site and couldn't find it.
My Apologies, I hit send send to quickly.
$pg_config = array(
and change it to:
$pg_config = array(
    'path' => "/".str_replace('galleries/', '', str_ireplace(str_ireplace('\\', '/', realpath($_SERVER['DOCUMENT_ROOT'])), '', $abs_prefix)),
    'html_prefix' => "/".str_ireplace(str_ireplace('\\', '/', realpath($_SERVER['DOCUMENT_ROOT'])), '', $abs_file) . '/'
kbettenc296716
No joy
That didn't seem to do anything. I even created a new powergallery called "Gallery" instead of "KBGallery"
mixedmedia.php
This time however, it tries to show the ribbon at the bottom and I see black outlined squares, but then they disappear.
Also, The link given in "direct link to gallery" doesn't work either, it says "page not found".
index.php?gallery=2&theme=light
I have created a support ticket so we can look into this issue with you. To view and edit your support ticket, please log into your support history:
kbettenc296716
Thanks for helping
