Extension won't be installed - again...again
Thread begun 1/06/2010 1:47 pm by eric341232 | Last modified 1/06/2010 6:30 pm by Office Guy-172461 | 2809 views | 2 replies |
eric341232
As a long-time WebAssist extension user it just drives me crazy that you all think all the installation bugs for all the extensions I use (validation toolkit, cookies, HTML editor) are just a matter of, well you know, just uninstall every extension and then reinstall them all, is like, you know, well... just like a drive around the park.
You squander a lot of goodwill.
Oh rename your configuration file and screw everything up. What a lark! That's so simple I don't know why I don't do it every day.
Deleting the cache file never works, by the way. Never. It does for some things but not WebAssist things.
I had to go through all this who-ha when I installed HTML editor to replace iRite. Rename the configuration directory, reinstall everything. Blah, blah, blah.
And now I have to do it all again just to install an update of validation toolkit. "Internal Error. Contact WebAssist support. Extension won't be installed"
WebAssist says: Hey, you know, like, just delete the cache file (again, doesn't work) or if that doesn't work, just uninstall and then reinstall everything. Ugh.
How about this? How about I just stop trying to upgrade and stop buying WebAssist extentions?
if you are running into these problems repeatedly there is obviously something else going on. With out some more details, it is hard to tell why you keep having this problem. here are some things to double check that may contribute to running into these issues:
1) before installing, save the .mxp file to your computer. When you click the link in the download center, you may be prompted to either open the file or save it, make sure to select the option to save it.
2) Instead of double clicking the MXP file to begin the installation, start the installation manually. In Dreamweaver, go to Commands -> Manage Extensions to open the extension manager. Once the extesnion manager is open, close Dreamweaver before proceeding. In the Extension Manager, click the install extesnion icon. Browse to the location where you saved the MXP file and select it to begin the installation.
3) If you are planning to install an updated version of an extension, first Uninstall the previous version from the extesnion manager.
4) When using the extesnion manager, always make sure Dreamweaver is closed.
5) Sometimes Anti Virus software, or other software that performs real time scanning on the file system can cause conflicts. Turn off your anti virus software before installing.
6) If you are on a Windows computer, make sure you are not installing while logged in using the Windows Administrator account, you should create a secondary user account, you can grant that account administrator privileges.
We have some youtube videos at the following URL:
webassist
that walk through the proper steps for installing and updating WebAssist Extensions.
Office Guy-172461
Originally Said By: eric341232
You might want to consider the possibility that there is an issue with your system. Others are having a different experience:
showpost.php?p=37160&postcount=3
