PRESALES enquiry
Thread begun 12/31/2009 10:26 am by keithlogan347721 | Last modified 12/31/2009 11:26 am by Jimmy Wu | 1853 views | 3 replies |
keithlogan347721
PRESALES enquiry
I'm considering on using PowerStore for a new client of mine. I have just built a static site and would be looking to add PowerStore to it. Is it possible to change the layout / design of PowerStore to match the look of the static site?
Can PowerStore use WorldPay, SagePay (formally Protx) and PayPal Payments Pro in the UK?
Jimmy Wu
You can change the layout to match with the format of your existing site.
By default, PowerStore is not set up to work with these payment gateways, but if you have eCart, you can modify PowerStore to work with these payment gateways. We have a guide on how to change the payment gateway:
ps_change_pmtgateway_ecart.pdf
keithlogan347721
In order to change the layout, is this via CSS or does PowerStore come with DreamWeaver Template files that you can modify?
Jimmy Wu
You would modify this using the CSS or you can apply a template to the pages. Here's a tutorial on how to modify the design on the pages:
sp_modify_design.pdf
If you go to the support page for PowerStore, you can see all the different tutorials set up for it:
powerstore/
