Image obscures menu
Thread begun 12/30/2009 6:05 am by Alan Shaw | Last modified 12/31/2009 11:22 am by Jimmy Wu | 7567 views | 13 replies |
Alan Shaw
Image obscures menu
It is best explained if you take a look, see here:
map.html
Looks fine until you use the menu.
Place pointer over 'Location' or 'Things to Do' and the 'pop out menu' disappears behind the image.
Any ideas why or how to solve this?
Alan
John LangerBeta Tester
I haven't tried this but try adding z-index:99999 to an li CSS style for the sub-menus (the ones that fly out).
Jimmy Wu
Make sure to set the position property of the menu items as well when you set the z-index.
Alan Shaw
Originally Said By: John Langer
Thanks John but I think that went over my head.
I have created the menu using WebAssist Menu Writer, I'm not sure where to add what you have suggested, I have the following files.
menu.ssi which as the extension suggests, is an include.
Then the folder automatically created by WebAssist which contains the following files:
menu.css
menu.js
menu_ie.css
menustyle.xml
treexml.xml
I guess it must be both css's but where, once again I guess at the '-1level'
I've had a play, but no success yet.
The code for 'menu.css' is as follows:
ul#cssmw {
cursor: default;
list-style-type: none;
margin: 0 0 0 0;
padding: 0 0 0 0;
width: 0;
ul#cssmw ul {
cursor: default;
font-size: 0;
margin: 0 0 0 0;
padding: 0 0 0 0;
ul#cssmw li {
background-image: none;
padding: 0 0 0 0;
position: relative;
white-space: nowrap;
ul#cssmw li ul {
display: none;
top: 0;
ul#cssmw li:hover > ul {
display: block;
position: absolute;
ul#cssmw > li {
ul#cssmw > li > a {
background-image: url("../cssmw_images/bg.jpg");
background-repeat: repeat-y;
border-bottom: solid 1px #9BB6D2;
color: #FFFFFF;
display: block;
font-family: Arial, Helvetica, sans-serif;
font-size: 12px;
font-style: normal;
height: 14px;
line-height: 14px;
margin: 0 0 0 0;
padding: 6px 10px 6px 6px;
text-decoration: none;
width: 134px;
ul#cssmw > li:hover > a {
background-image: url("../cssmw_images/grad.jpg");
color: #0D092B;
ul#cssmw ul.level-1 {
left: 150px;
ul#cssmw ul.level-1 > li {
ul#cssmw ul.level-1 > li > a {
color: #FFFFFF;
display: block;
font-size: 12px;
font-style: normal;
height: 14px;
line-height: 14px;
margin: 0 0 0 0;
width: 134px;
ul#cssmw ul.level-1 > li:hover > a {
color: #000A5C;
ul#cssmw ul.level-2 {
left: 150px;
ul#cssmw ul.level-2 > li {
ul#cssmw ul.level-2 > li > a {
color: #FFFFFF;
display: block;
font-size: 12px;
font-style: normal;
height: 14px;
line-height: 14px;
margin: 0 0 0 0;
width: 134px;
ul#cssmw ul.level-2 > li:hover > a {
color: #000A5C;
ul#cssmw ul.level-3 {
left: 150px;
ul#cssmw ul.level-3 > li {
ul#cssmw ul.level-3 > li > a {
color: #FFFFFF;
display: block;
font-size: 12px;
font-style: normal;
height: 14px;
line-height: 14px;
margin: 0 0 0 0;
width: 134px;
ul#cssmw ul.level-3 > li:hover > a {
color: #000A5C;
Jimmy Wu
Looks like in the actual site, you have put z-index: 99999; into this block:
color: #FFFFFF;
display: block;
font-size: 12px;
font-style: normal;
height: 14px;
line-height: 14px;
margin: 0 0 0 0;
width: 134px;
Make sure you also add position: relative; to that block as well. The z-index will not work unless the position is also specified.
Alan Shaw
Jimmy, thanks for your reply mate but that has also gone over my head.
But, whilst I didn't understand exactly what you meant, I change the block to this by adding the last two lines:
color: #FFFFFF;
display: block;
font-size: 12px;
font-style: normal;
height: 14px;
line-height: 14px;
margin: 0 0 0 0;
width: 134px;
z-index: 99999;
position: relative
but, it didn't work, have I done the right thing?
Alan Shaw
it seems I am not the only one suffering, I Googled the problem and found this top of the list:
google-maps-and-cssjavascript-drop-down-menus
Jimmy Wu
It looks like the menus are showing up over the map now for me. What browser are you using to view this page?
Alan Shaw
Good thinking Jimmy, (it's late here)
Works in Firefox but not in IE8
But here is the sting.
In Firefox, just looking at the 'home page' and using the menu, the last item on the menu is obscured by the footer, yet in IE8, it isn't.
So it would seem both have their faults.
neilo
Possibly unrelated, but don't forget to place a semi-colon after 'relative':
z-index: 99999;
position: relative;
