Problem with redirect
Thread begun 12/22/2009 7:13 pm by jcc1202396761 | Last modified 1/04/2010 2:10 pm by Jimmy Wu | 6949 views | 16 replies |
jcc1202396761
I would like to change the redirect from the user profile page to my Home Page. After reasing posts in this forum I modified users_login to reflect my homepage by changing redirect from users_profile to index.php.
Now I am getting the following error:
Warning: main(file:///C|/Users/AFGL/AppData/Local/Temp/Temp1_UserRegistration100(2).zip/Connections/localhost.php) [function.main]: failed to open stream: No such file or directory in /home/content/67/5286467/html/users_LogIn.php on line 1
Fatal error: main() [function.require]: Failed opening required 'file:///C|/Users/AFGL/AppData/Local/Temp/Temp1_UserRegistration100(2).zip/Connections/localhost.php' (include_path='.:/usr/local/lib/php') in /home/content/67/5286467/html/users_LogIn.php on line 1
Any ideas?
Thanks in advance
Are you trying to browse the page from a .zip file? you will want to put the page onto your web server and browse with a url that begins with http:// and not file://
jcc1202396761
Error
I downloaded your files to my desktop. Then, after making changes in your "get Started" help file, I used my server's (goDaddy) ftp client to transfer the files. I then tested the application on my website and it worked as expected. However, I wanted the redirect to go to my home or, better yet, the URL it was blocking acces to. Right now it takes me to the Update Page and when I press the link on the page I get a page with one line indicating that my email has been verified. The error resulted when I attempted to change the 2 instances of "successRedirect" => "index.php", as shown. If I then correct the successRedirect statement to its original form, I continue to get the error. The only way to correct seems to be reinstallation of all the original files on the server.
That is my primary issue. Of much lesser importance is the registration form does not specify the criteria for adding a password in the correct format. I see the statement in your code, but it does not appear on the page during initial registration.
Your thoughts?
What is the url of the page on the live site? I can see if I can spot the problem that way.
You may have to set up a site in Dreamweaver when you edit the files so that the paths will be referenced correctly when editing. That could have been the source of the problem when updating the redirect.
jcc1202396761
site url
The Url is afewgoodlines.net The protected page, at the moment, can be accessed by choosing the "Pink House" link.
I can't seem to find the link to the page. I clicked on the Pink House option in the menu, but that just took me to the catalog.
jcc1202396761
up and running
I returned the site to it's original status by again, removing the program and reinstalling on the server. It is working but I still cannot make any changes to code without generating error codes.
You should be able to find in the code where the original page name is referenced and just update that manually in the code if that is all you need to update.
If you supply a url where I can view the errors after you make the update I can try to give more information from there.
jcc1202396761
url revisited
Ok changed the login page such that I now have 2 instances of this line:
I am now getting the error again.
Use the link: afewgoodlines.net/PinkHouse.php for the protected page.
jcc1202396761
found something curious in file
I just noticed that when I put users_login on the remote server Dreamwever inserted the following code at the top of the page:
<?php require_once('file:///C|/Users/AFGL/AppData/Local/Temp/Temp1_UserRegistration100(2).zip/Connections/localhost.php');?>
<?php require_once("file:///C|/Users/AFGL/AppData/Local/Temp/Temp1_UserRegistration100(2).zip/WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("file:///C|/Users/AFGL/AppData/Local/Temp/Temp1_UserRegistration100(2).zip/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
<?php require_once( "file:///C|/Users/AFGL/AppData/Local/Temp/Temp1_UserRegistration100(2).zip/WA_SecurityAssist/Helper_PHP.php" ); ?><?php
This appears to be the problem? As I do not know php, I am not sure how to modify this code. My page, index.php is in the same directory as users_Login.php.
