Default view on the sat one
Hello.
How can i set up the default view on the sat one?
Thanks.
Hello.
Thanks.
Back-up your wagmp_map_1.php file in case you need to revert to it.
In your wagmp_map_1.php file (it may have a different number on the end) find the line of code (about line 115):
var map = new GMap2(document.getElementById('wagmp_map_1'));
Place the cursor at the end of the line and press the return key to create a new line, and add this line:
map.setMapType(G_SATELLITE_MAP);
Edit (add): For a hybrid map it would be:
map.setMapType(G_HYBRID_MAP);
Thanks Neilo, just to add on, you may find this thread helpful:
showthread.php?t=3719
It shows all of the possible map types that can be used.
