Setting Default Map View?
Thread begun 8/30/2009 4:00 pm by Martin | Last modified 8/31/2009 1:59 pm by Jason Byrnes | 7231 views | 5 replies |
Martin
Greetings!
I was wondering if anyone knew how to (or where to change) in the code change the default map view from Map, to either Satellite or Hybrid using this extension?
Any help would be appreciated!
Martin
In the wagmp_map_1.js file, find the following:
function wagmp_map_1() {
if(GBrowserIsCompatible()) {
if(!document.getElementById('wagmp_map_1')) return false;
var map = new GMap2(document.getElementById('wagmp_map_1'));
and add this on the next line:
map.setMapType(G_SATELLITE_MAP);
The following is from the google map api introduction:
introduction.html
The following map types are commonly used in the Google Maps API:
* G_NORMAL_MAP displays the default road map view
* G_SATELLITE_MAP displays Google Earth satellite images
* G_HYBRID_MAP displays a mixture of normal and satellite views
* G_DEFAULT_MAP_TYPES contains an array of the above three types, useful for iterative processing.
* G_PHYSICAL_MAP displays a physical map based on terrain information.
Martin
Jason, that worked awesomely!
That is a great reference, I spent hours yesterday trying to find this, but nothing as specific and exact as what you have provided me with.
I will save this for future reference!
Thank you!
Martin
Excellent, glad it's working.
Martin
Much appreciated!
Jason, would this not be a good feature request to add in to the Google Maps pro extension as well as the ability to customize the zoom level setting of the map (a question that has been asked repeatedly in this forum)?
Having them as entries that can be filled out/selected in the wizard would be a nice upgrade!
Thanks again...
Martin
You can post your comments on features you would like included in future version on the wishlist forum.
THere is a tutorial for changing the zoom level on the how to section of the pro maps support page:
pro_maps_set_zoom_level_ht.pdf
