2 quick questions
Thread begun 12/20/2009 11:52 am by gruant2000381341 | Last modified 12/21/2009 11:25 am by Jason Byrnes | 2191 views | 3 replies |
gruant2000381341
2 quick questions
I find myself working in source view quite a bit when adding content via cms. The problem is that all the code is slammed together, making it difficult to keep track of where I need to be.
1. is there a way to force that code view to be in "line by line" layout rather than "no white space"(for lack of a better word)
2.if not, will I mess anything up by adding some comment lines?
1) in both of the .js files in the WA_iRite/custom directory, find the following 2 lines:
FCKConfig.FormatOutput = false;
FCKConfig.FormatSource = false;
and change them to:
FCKConfig.FormatOutput = true;
FCKConfig.FormatSource = true;
2) Adding comments in the code should not have a negative effect.
gruant2000381341
thank you, that makes it sooo much easier !
no worries.
