How do i make these are active so I can change them
Thread begun 12/11/2009 4:29 pm by GaryDCoxDFW | Last modified 1/05/2010 10:12 pm by neilo | 4165 views | 8 replies |
GaryDCoxDFW
I want to change my home page tah was made in site assiste assist pro, I have all your products so I a wnderin how to do this with your products. I am up loadig a screen shot of the present page and will give yo the following location of the test site of:
test.dachtml.ultrawatercreations.com/
I will start redoing the page in php to take advantage of the php function, what i want to do is remove the banner no problem for me the menu system, and move it to the area that has the copy of New England premiere propertes, the area is not active for editing at this time how do i accomplishthis, i also want ot do this to the place where the pocture of the sailing ship is and use a flash extension to put a presentation in it's place once again I can not work in this area, all of this is just a lack of knowledge of the proper way of useing the webasiss extensions and the proper modification techniques after using the tools.
Jimmy Wu
The pages are created using a template, so if you want to make all parts of the page editable, you can detach it from the template. You can do this by going to the modify menu in Dreamweaver and then going to the template option and select detach from template. You can then make changes and apply the template again afterward.
Another way you can make changes is to go into the template file and make these changes and apply them to the other pages.
GaryDCoxDFW
THe area is grayed out now what
What now??
Jimmy Wu
Detach from template.
GaryDCoxDFW
detach from template is grayed out
Well I also tried it on a new site I am working on same reaults on a different computer, am I missing something? Suggstions"??
neilo
Detaching a page from Template
If the reason you are having difficulties is because areas of your page are locked because they were created from a template, then the link above shows you how to detach it.
If you are experiencing other problems, you need to post back with full details of what you are seeing and what you are trying.
Could you also upload your page and provide a link for us to see the page?
GaryDCoxDFW
Tried it. it did not work
The detacth was grayed out, I had done it right.
Test website is at: asptest.icantiemyshoes.com/
neilo
Hi there,
Thanks for that. Yes, you were right. The reason that the area with the picture of a sailing ship and the 'New England premiere properties' seems to be un-editable, is that the top part of that area (the contentWrapper div) is one large picture as defined in the css for that div. You can see the image HERE
If you want to remove that image so that you can replace it with your own content, you could either do it while using the SiteAssist to design your site, or now that it's done, you could just remove a couple of lines from your 'siteassistpro_css/home.css' stylesheet:
Find the following block of code in the stylesheet:
#outerWrapper #contentWrapper {
background-image:url(../siteassistpro_images/contentWrapper_bg1.jpg);
background-repeat:no-repeat;
margin-left:10px;
margin-right:10px;
overflow:hidden;
padding-top:361px;
And take out the second, third and sixth lines, and change the last line:
margin-left:10px;
margin-right:10px;
padding-top:10px;
'padding-top:361px;' that will have made this hard for you to detect, - it effectively 'shields' that area against editing!]
Any content you add should sit above the left column and content (which are two divs in the bottom half of the contentWrapper)
Hope this helps. Sorry you had to wait so long; - if you get more problems, be sure to post a link to the page you need help with, it makes diagnosis much easier, and quicker.
neilo
What also might be helpful:
To make it easier to see the new space you have and to place your cursor in it, go to line (at or about) line 150 of your page, and immediately after:
<div id="contentWrapper">
add the following line:
<div id="content_top" style="margin-left:20px; margin-right:20px; margin-bottom:10px;">Content for your top space Goes Here</div>
