asp vbscript ecart code in universal email
Thread begun 12/09/2009 1:28 pm by cheryl75100 | Last modified 1/13/2010 12:34 pm by Jason Byrnes | 3617 views | 5 replies |
cheryl75100
Can someone give me the code for sending the contents of the ecart in the body of the Universal email receipt?
that code will not be the same for everybody. most likely, the code someone gives you will not work.
In the Universal Email wizard, go to the body tab and click the DW Edit button. This will open a Dreamweaver template page. Place your cursor in the blue editable region, then go to Insert -> WebAssist -> ecart -> Cart Display Manager. For the display type, make sure to select email friendly, then click OK to apply it.
After the cart display has been applied to the email template page, go to File -> Save, this will bring you back to the universal Email wizard. Click the OK Button to finish applying Universal Email.
cheryl75100
I don't have a DW Edit button in the body tab
What version of universal Email are you using?
Can you send a screen shot of the body tab?
cheryl75100
2.8.0
I have attached screen cap of body
Ok, you are using Universal Email 2.x.
To create the cart display, start a blank page. Go to insert -> webAssist -> eCart -> Display Manager
make sure to chose the correct eCart object and set the display type to Email friendly.
Now copy the code that is added between the body tags, then open universal Email and paste that code in the body window.
