no emails sent
Thread begun 12/08/2009 10:28 am by i.edwards384429 | Last modified 12/09/2009 2:47 pm by Jason Byrnes | 4715 views | 9 replies |
i.edwards384429
no emails sent
Hi
from a previous thread I modified the mail_php file
PHP:
$mailObj = mail($mailTo,$mailSubject,$mailContent,$mailHeader, "-f".$mailFrom);
for the security assist pages, make the same code change to the WA_SecurityAssist/Mail_PHP.php file.
Since the modification (thanks for that) the email side of the user registration solution works perfectly however the pages created by the security wizard do not send emails.
I've attatched the php file can you see anything wrong
thanks
Ian
Please send a copy oif the security assist email password page so I can see how it was configured.
i.edwards384429
files
Hi Jason
I've attached the files you might want to look at
thanks
Ian
It doesn't look like you included the Email Password page. I need to look at the code on the page that you applied the email password server behavior.
i.edwards384429
upload file
Hi Jason
is this the file you want?
thanks
Ian
Yes, that's the page I needed.
Interesting it looks like it is configured properly.
When you submit this page, are you redirected to the photographers_LogIn.php page?
If you are not redirected to the photographers_LogIn.php page, change line 25:
"failRedirect" => "photographers_EmailPW.php",
"failRedirect" => "photographers_EmailPW.php?failed=true",
and try again. when the page reloads, do you see the failed=true query string on the end of the address in the address bar?
try deleting the WA_SecurityAssist/Mail_PHP.php file from the server, then re uploading the modified one to make sure the changes are being uploaded to the server.
i.edwards384429
update
Hi Jason
OK I changed the code as you said and when I fill in the email request I am not sent back to the login page but I do see in the address bar
failed=true
Where do I go from here?
Shall I delete the pages and start again?
cheers
Ian
So that means that it is not finding the email address you are entering in the database.
Check the following:
Make sure you are using an email address the database.
Double check the UserEmail column in the photographers table to make sure that email addresses are being stored properly when a user registers.
i.edwards384429
update
Hi Jason
you were correct is that the info was not be ing written to the database.
It now is and the email is formatted correctly.
I filled in the password reminder and got all excited because it returned me to the logon screen.
However still not email received.
Off to beddie byes here now 10pm a
any ideas where I go from here
thanks
Ian
Try leaving the From Display Name blank in the Email Password server behavior.
Keep in mind that if you edit the server behavior, the mail_PHP.php file will be overwritten, you will need to add the -f argument to the mail() function call again.
make sure the email is not being trapped as spam also.
If all else fails, check with the host. Ask them to look into the SMTP server error logs to see why the server is not relaying the email.
