Bad links generated (GoDaddy Host)
Thread begun 12/07/2009 9:59 am by info262805 | Last modified 2/02/2010 6:19 pm by Jimmy Wu | 6287 views | 8 replies |
info262805
I am unable to get the Power Gallery product to function correctly under a GoDaddy account. I've tried the few posts out on the forums with no luck:
The Add to Site link that is generated from the Admin system is:
index.php?gallery=1&theme=light
This is obviously not correct. I'm able to get to view a page if I change the address to:
But it doesn't display the photos or other graphics. Just Loading.....
Any help would be greatly appreciated. Thanks.
in the galleries/global.php file, change line 14:
$_SERVER['DOCUMENT_ROOT'] = str_replace( '\\', '/', substr(str_replace('\\\\', '\\', $_SERVER['ORIG_PATH_TRANSLATED']), 0, 0 - strlen($_SERVER['PHP_SELF'])));
$_SERVER['DOCUMENT_ROOT'] = str_replace( '\\', '/', substr(str_replace('\\\\', '\\', $_SERVER['PATH_TRANSLATED']), 0, 0 - strlen($_SERVER['PHP_SELF'])));
info262805
Thanks for your reply.
I didn't have this line of code in 14, but in line 10. It was already set they way you wanted. See below:
//make sure the $_SERVER['DOCUMENT_ROOT'] variable is set (IIS doesn't set it)
if(!isset($_SERVER['DOCUMENT_ROOT'])) {
if(isset($_SERVER['SCRIPT_FILENAME'])) {
$_SERVER['DOCUMENT_ROOT'] = str_replace( '\\', '/', substr($_SERVER['SCRIPT_FILENAME'], 0, 0 - strlen($_SERVER['PHP_SELF'])));
if(isset($_SERVER['PATH_TRANSLATED'])) {
//$_SERVER['DOCUMENT_ROOT'] is now set
info262805
but still get the same results
I have created a support ticket so we can look into this issue with your to find the solution. to view and edit your support ticket, please log into your support history:
Ropey
I have the same problem, would you be able to help me out by telling what else needs to be changed? it keeps saying 'loading' sometimes, not allways.
can you post a link?
What browser are you using to test?
info319155
I also have image links and loading problem
Hi. I think this is the same as my problem too.
I had PowerGallery working fine on a testing site. Please see:
residential.php
But when installed on client's site
residential.php
the images will not load. On Firefox it just says loading and on Safari you see broken links to images.
My global.php is as you say it should be. I have noted that the PHP link looks different to that of my testing site? Testing site looks like:
$pg_id = '1';
$pg_theme = 'light';
include('/var/www/vhosts/123design.co.uk/subdomains/testing/httpdocs/images/gallery/PowerGallery100/galleries/ribbon_fullsize_brooks_2/index.php');
Client site looks like:
$pg_id = '1';
include('/vhost/vhost8/b/r/o/brooksarchitects.com/www/images/gallery/PowerGallery100/galleries/ribbon_fullsize_brooks_2/index.php');
Might this be a problem with the host? Help appreciated asap.
Janice
Jimmy Wu
I have gone ahead and answered your question in another thread you made here:
showthread.php?t=9681
If you run into any additional issues, feel free to open a new thread.
