Gallery will not load on site
Thread begun 1/30/2010 4:37 am by info319155 | Last modified 2/17/2010 7:20 pm by Dani Chankhour | 6965 views | 7 replies |
info319155
Hi.
I had PowerGallery working fine on a testing site. Please see:
residential.php
But when installed on client's site
residential.php
the images will not load. On Firefox it just says loading and on Safari and IE you see broken links to images. This was a fresh install of PowerGallery.
My global.php is as you say it should be in another thread. This is how the PHP link looks on my testing site:
$pg_id = '1';
$pg_theme = 'light';
include('/var/www/vhosts/123design.co.uk/subdomains/testing/httpdocs/images/gallery/PowerGallery100/galleries/ribbon_fullsize_brooks_2/index.php');
Client site looks like:
$pg_id = '1';
include('/vhost/vhost8/b/r/o/brooksarchitects.com/www/PowerGallery100/galleries/ribbon_fullsize_brooks_2/index.php');
I have just tried a complete reinstall of PowerGallery, resiting the folder to see if that made a difference. I have checked the database and thought of everything I can. Now very stuck and desperate with impatient client.
Please help urgently! Thanks.
Help appreciated asap.
I have just done a test of PowerGallery on the same host provider, www.easyspace.com/, with a plain page and there is the same loading problem. I think it is the host. So, is there any work round or do I have to change host for my client? This will be embarrassing! Help needed fast.
Janice
Looks like this is because your server is setting the path as:
for an image.
This part is extraneous:
This is the correct path:
I am attaching an updated version of the global.php specific to your setup that will remove the extraneous part of the path for you. Let me know if this works for you.
info319155
global.php not doing the trick
Thanks for assistance. Unfortunately this has not solved the problem.
Hope you can find another answer.
Janice
Which global.php file did you replace? Was it the one in the galleries directory?
info319155
Oh joy!
No, it was the wrong global.php. Have now replaced the one in the galleries and it works!
I cannot say how grateful I am for your assistance. Thanks so much. Top marks, yet again, to WebAssist technicians.
Regards, Janice
Glad to hear it works for you. Make sure you revert the other global file back to the original form. If you run into any additional issues, feel free to open a new thread.
e394610
PG not working for me
I think I am having a similar issue as these few posts on the subject, but have not seen a solution in the open. I apologize if I missed it anywhere.
Anyway, everything was successful during the installation, but when I added the php code into the page below it does not view properly. No photos, etc. All photos processed successfully during the installation.
photos
This is the http: address the admin provides:
index.php?gallery=1&theme=dark
Obviously the link should be:
but this link above is the same issue as when adding the php into the first link. Photos load, but nothing is viewable.
I am using firefox browser version 3.5.7
I am hosted at Godaddy
I have windows vista
Also, I can log into the Admin part of the site and add or edit photos.
Ernie
Dani Chankhour
I replied to your post here:
showthread.php?p=44364&posted=1#post44364
