CSS Form Builder, Universal Email and Validations
Thread began 11/27/2009 4:07 am by adamop11392849 | Last modified 11/27/2009 5:06 pm by adamop11392849 | 1411 views | 1 replies |
adamop11392849
I create a contact from using FB and I email that form using UE. I have noticed that when validations are applied to the form, the email is mot sent. In more details:
1. Creation of a contact form with validations (required fields) using FB>>>Applying the UE>>> form is not sent.
2. Creation of a contact form with validations (there is at least one required field because of the CAPTCHA field) using FB>>>removing validations in DW>>applying UE>>> form is sent
3. Creation of a contact form (there is at least one validation field because of the CAPTCHA) using FB>>>removing the validations in DW>>applying UE>>applying validations using FB (no other changes)>>>form is not sent.
4. Creation of a contact form using FB>>>removing validations in DW>>applying UE>>>applying spry validations in DW>>>form is sent.
I am wondering if I can use FB to apply validations to a contact form using UE?
adamop11392849
I found where is the problem
I found out that the FB, when a file field is included in the form for uploading like an attachment, makes this field to be required, even if you don't check it as required. In this case, when this attachment is included in the UE, the form is not sent without reporting an error and returns in the page where the form is. To resolve the problem, I deleted the validation in the server behavior pannel as also I deleted the appropriate line in the WA validation. If the file field (attachement) is checked as required from the beginning then this problem doesn't appear.
