just started using my ecart
Hi ok i have uploads to a test page put it only shows the files please see myshop/
any help please
any help please
double check with your hosting provider that they support ColdFusion, it doesn't look like they do.
it is an Apache server, so they should support PHP. If you do not want to change to a ColdFusion host, set the Server language in Dreamweaver to PHP and recreate the cart pages.
Ok thanks i have changed to php and now the the pages shows up but not the cart ???? myshop/ ?
What page did you put the add to cart button on?
Have you tried following the eCart getting started guide on the ecart support page:
ecart/
yes but can not seam to find how to add products/items
ok pls have a look myshop/ its showing add to cart btn but no items if you click on the btn it go to Your Shopping Cart any help pls
I'll need you to send copies of your pages in a zip file so I can examine the code please.
