CSS Form Builder - Re-enter Wizard
Thread begun 11/18/2009 2:22 pm by dlovas275157 | Last modified 11/19/2009 11:34 am by Eric Mittman | 2861 views | 3 replies |
dlovas275157
I have created a form and successfully edited it in CSS Form Build. I would now like to go back into CSS Form Builder and may a few changes. However, when I place my cursor inside the form and select "Insert > WebAssist > CSS Form Builder > Insert Form" to get to the wizard, the wizard does not recognize the existing form.
How do I go back and re-edit my existing form in CSS Form Builder?
neilo
Hiya dlovas,
In design view in Dreamweaver, when you click anywhere inside the form, do you see a thin blue line surrounding all the elements?
If it is there, click the mouse anywhere exactly on that line. You should now be able to see the 'edit form' edit design' and 'edit contents' buttons in the properties panel (inspector).
dlovas275157
Thanks. I was clicking "anywhere inside the form" instead of "on the thin blue line surrounding the form". Thanks again. That worked.
In addition to the blue line that you see around the form you can also just select the form tag from the area directly beneath the code or design view, I find this to be a quick way to get to the edit options if I'm in the code view at all.
