Can't insert Form Builder data into record using DataAssist insert record
Thread began 11/12/2009 10:10 am by mywebassist220499 | Last modified 11/12/2009 2:09 pm by Jason Byrnes | 1335 views | 3 replies |
mywebassist220499
Using:
Latest WA extension version
DW CS3
WinXP SP3
PHP
mySQL
I'm posting this in the form builder forum since this is happening with a Form Builder form. (Have not had this problem with DataAssist pre CSS Form Builder.
I've created a custom form using CSS Form Builder. Using Data Assist's insert single record behavior, it does not insert the data into the record. A new record is created and the fields with default data are populated but all of the fields expecting form data are blank.
I have made sure that all CSS FB and DataAssist files are uploaded.
I then removed the Data Assist behavior and used the DW CS3's own insert record behavior. (same form, same page). Using DW's behavior works.
top of page code (DataAssist version) is in attached file.
Thanks,
David
top-of-page-code.txt
Your binding the database columns to the validated fields collection on the Bindings panel.
The Validated Fields collection is only populated if the form Fails Validation.
You need to use the Form Collection on the bindings panel instead of the validated fields collection.
mywebassist220499
That was it Jason. Thanks lots!
Best,
David
You're welcome.
