Validation Errors
Thread begun 11/02/2009 11:09 am by bill173836 | Last modified 11/03/2009 9:23 am by Jason Byrnes | 6226 views | 8 replies |
bill173836
Validation Errors
I've reinstalled VT several times and even have tried to fun it without any other extension turned on and I keep getting these error messages:
While executing onLoad in WAFV_Required_C.htm, a JavaScript error occured.
While executing onLoad in WAFV_AlertsErrors_C.htm, a JavaScript error occurred.
And the validation doesn't work.
Office Guy-172461
Solving problems with Dreamweaver
Have you tried step 1:
146/
bill173836
Yes, I have tried that.
Office Guy-172461
Found this thread that might help:
showthread.php?t=3686
bill173836
I looked at this thread and it wasn't much help. It does appear that they are having at least a similar problem. I'm running on a Mac. I've tried using CSS Form Builder & Validation Toolkit and have the same problem with both.
Office Guy-172461
What happened when you installed the new file?
You cannot have both CSS Form Builder and validation Toolkit installed at the same time. You can only have one of them installed at a time. This error you are geting is specific to CSS form builder.
There is a known issue about it on the CSS form builder Download page in the known issues section.
you may also need to delete the Dreamweaver Cache file:
bill173836
I currently only have the CSS Form Builder installed. I deleted the file and the problem persists.
Have you also seen the known issue on the CSS Form builder download page and placed the updated files in the proper locations?
The files in the Known Issue pack on the CSS Form builder Download page should fix the problem.
