WAFV_Required_C.htm error message
Thread begun 8/28/2009 2:39 pm by tom92909 | Last modified 8/31/2009 4:17 pm by Jason Byrnes | 5372 views | 5 replies |
tom92909Beta Tester
I'm using the new Client Side Validation from the CSS Form Builder. I'm adding the validation to a fresh form page.
I get the following error immediately when I attempt to add any Required options.
While executing onClick in WAFV_Required_C.htm, a Javascript error occurred.
screenshot
I am sending a copy of the WAFV_Required_C.js file that should address the error.
Please copy it to the following location:
Win Vista:
C:Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver 9\Configuration\Behaviors\Actions\WA Validation Toolkit\Apply Client Validations
WinXP:
C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver 9\Configuration\Behaviors\Actions\WA Validation Toolkit\Apply Client Validations
tom92909Beta Tester
Thank you for your response.
I did as instructed and this did not fix the problem.
I went ahead and killed the \Application Data\Adobe\Dreamweaver 9\Configuration directory and re-installed all of my extensions (1 hour later) I still still have the same problem.
What's happened to my Validation Tool Kit?
tom92909Beta Tester
I still have the same issue after placing the file in the following directories.
\Application Data\Adobe\Dreamweaver 9\Configuration\Shared\WebAssist
\Application Data\Adobe\Dreamweaver 9\Configuration\Shared\WebAssist\Library
\Application Data\Adobe\Dreamweaver 9\Configuration\Shared\WebAssist\FormBuilder
\Application Data\Adobe\Dreamweaver 9\Configuration\Shared\WebAssist\FormBuilder\Library
\Application Data\Adobe\Dreamweaver 9\Configuration\Shared\WebAssist\FormValidations
\Application Data\Adobe\Dreamweaver 9\Configuration\Shared\WebAssist\FormValidations\Library
\Application Data\Adobe\Dreamweaver 9\Configuration\Shared\WebAssist\FormValidations\Scripts
I will need to look into this with you. I have created a technical support ticket so we can look into this issue further.
To view and edit your support ticket, log into your Support history:
The file needs to be copied to the following 2 locations:
Win Vista:
C:Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver 9\Configuration\Commands
WinXP:
C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver 9\Command
